6н1п+6п14п SE без оос
How does the amp sound?
I have built some el84se and ecl 86 , but i am not satisfied with the sound. I used some opt who came from some old radios...
Hope the ukrainian people will get some peace soon!!
sound quite happy, this is the first tube amp, built on the ruins of the old tube TVs, and by the way the construction itself cost a penny.
Next my SE 2E26 & 6Н8С. I changed 815 to 2E26 GE. Heating 6.3 V, Ia about 35 ma, Bias minus 15 V, output power about 1.5 W. Sound is brightest than another my tubes /ex. my OTL/. Picture is with 815, that was changed to 2E26 GE. Plate is inside on the balloon.
https://picasaweb.google.com/109570777566485968551/Amplifiers#6108235820775591122
http://frank.pocnet.net/sheets/049/2/2E26.pdf
I like the aircraft switch
congratulations
congratulations
yes definitely noticed the switch from an 26
This is only bamboo tray that I bough from market, and I used for my experimentsAzazello, nice case work! I like to see wooden chassis.
Today I put on this tray Russian 30П1С with the same pretube 6Н8С and the sames big OTs....After listening I thing hard, IMO, this is the best Russian tethrod from all Russian tetrods and penthods, that I tried. I thing the best are EL11 Telefunken, 30П1С /30P1S/, 4П1Л /4P1L/ and ......This is only bamboo tray that I bough from market, and I used for my experiments
IMO, I think, the best LF sounding have output triodes, like 2A3, 45, 6BL7, 300BJJ, Sovtec /I put 6BL7 before 300B/, maybe 6S4S and Amer. variant....These tubes sound deepest....
TV tubes are more for MF and HF. Tubes, that I tried, E236L, E130L, 6P36S, 6P45S, 2E26, PL...decrease LF from 40-30 Hz.
I didn't tried big quantity of tubes, but every time, when I try different output tubes, result, IMO, is like above. Sorry, Your opinions maybe are different....
3D21b AB2 amp
3D21B AMP;
Does Anyone have the data for the 3D21B; I can find 3D21, 3D21A, 3D21WA,3D21WB, but not 3D21B.
The 3D21 has 15 watt plates the 3D21WA, 3D21WB have 40 watt plates, I have no idea what the 3D21B has
Phil
3D21B AMP;
Phil
3D21B AMP;
Phil
http://frank.pocnet.net/sheets/201/3/3D21A-B.pdf
15W plates.
leadbelly
THANKS
Phil.
I have lots of NOS 3D21WA/WB but all of them are Gassy none of the 3D21/3D21A, 3D21B are.
THANKS
Phil.
New stuff
This one looks really nice, especially if you like vintage amps like I do. It looks old but it's just an illusion. I should take better pics for this one and maybe open a thread to explain what it is all about. Maybe someday.
Oh I forgot...
I built this phono pre for a friend, nothing fancy, just a quickie. Anyway, he's pretty happy with it and listens to records everyday. He's weird this friend of mine, only plays singles. No LP's no CD's ....huh? Pre sounds pretty good. 6DJ8's....designed by.....oh I forgot his name.
My SE ECC88-EL83-6KD6 amp.
Very nice finish....is you 6KD6 in triode mode? do you maind sharing your schema?
thanks
Bottlehead Mainline Headphone Amplifier
Neat balanced headphone amplifier from Bottlehead. Uses 12AU7 for power and two 6C45-Pi. This build features a powdercoated antique copper top plate, copper-leaf wood base, big 10uF Jupiter capacitors, and classy Cardas copper wire.
Enjoy the pics! Build log with lots more photos and details here.
thanks
6KD6 included in triode mode.
Amplifier also includes two way crossover.
- Tubes / Valves
- Photo Gallery
