Photo Gallery
RIAA
in continuation. MM phono stage. correction in the anode. tube EF91? ECC40
Hi all, I just finished some days ago my EL34 single ended amp.
Driver stage by 6CG7 (SRPP) with a small amount of NFB. I inserted at a later time a dpdt toggle switch to go from triode mode to U.L.
I built the side part from wood as. Then I obtained the upper metal shelf starting from the cabinet of an old desktop pc which later I sprayed with heat-resistant satin black paint.
Nice build.
Here are three of my latest tube builds; “Cadence” - SRPP with Grant Fidelity Spheres, “Shu” - 50 Year Treasure with Golden Dragon rec. tube (both lreamps) and “Priory” - tube headphone amp. All builds use 1W carbon film resistors in the signal path.
Nice builds. I'm a big fan of Golden Dragon, a much underrated tube. I use their 300Bs, and find they have superior tone to even JJs. I bought a matched pair for $100 on eBay.
Here are a few years earlier. Still a mix but i like making tube gear over SS and class D. So much tube gear in the last few years because i had boxes of costly new tubes. Some had been sitting around for 20 years. In 2020 (mostly during lockdown) i started building with what i had on hand. Still got at least a few more tube wonders to complete.
retro-thermionic: 2018
retro-thermionic: 2019
