Photo Gallery
Business Card Buffer 🙂
Stereo 9AJ buffer with a 2x3.5 inch footprint. 🙂
Designed for Zin >10k. Zout ~600R
Reactions: aroS3
Thanks, the HY615's are proving to be hard to get hold of, one has a temporary heater cathode short on power up, tap it with a stick and it goes quiet.
By the way, my word of advice: use rubber grommets for the holes
I know, I ran out of grommets but made sure the holes were sharp edge free.
Thanks, yes, the preamp is my own work too,I too am smitten with the remote, the board etc is only a tad over £10, it has a fake Alps pot but I replaced that with a real one.
TFL, Andy.
Because I always need more, 2nd project: Big Boy: 100W (measured) with 6x 6L6 in PP (pentode mode - automatic biasing), homemade transformer made from 300VA core. Sounds loud and very aggressive.
EL34 amp
Hi all, I just finished some days ago my EL34 single ended amp.
Driver stage by 6CG7 (SRPP) with a small amount of NFB. I inserted at a later time a dpdt toggle switch to go from triode mode to U.L.
I built the side part from wood as. Then I obtained the upper metal shelf starting from the cabinet of an old desktop pc which later I sprayed with heat-resistant satin black paint.
indaco,
Your amplifier looks very attractive.
Good work!
What are your loudspeakers?
I bet there are nice sounds both in Triode; and nice sounds in U.L.
Perhaps the best selection of Triode / U.L. is according to the music, and volume required?
Is there a B+ choke under the hood?
Thanks!
Thanks 6A3sUMMER!
I choose one instead the other depending upon the music I listen to.
I find the triode more intimate and sweet, UL especially with certain passages (ie orchestral or organ) is more captivating.
Yes, the choke is just under the trasfo, in the psu unit inside. As soon as I can I'll post the photo of the "guts"
Good morning.
Here's the inside of the amp. Then I upgraded the signal capacitors with a pair of Jentzen superior (initially they were cheap ones). Cathode bypass capacitor for the drivers are the green Nichicon Muse BP
Thanks!
If you mean the cubic aluminium enclosure above I got it from another DIYer living in France, together with a pair of Al enclosures for the OTs.
The transformer has been rewound by myself, 150VA , with B+ secondary made from 0.48mm dia. Ouput B+: 0-310V for heaters: 0-6.3V and 3.15-0-3.15V.
Now running at B+ 330Vdc, in the psu it's employed a C-L-C-R-C (+another final R-C to the driver tubes)
DIY Revival of the Extinct TTVJ Sangaku
Featuring the Korg Nutube 6p1 Directly Heated Triode
Very nicely done. What are you using as vibration damping, two layers of foam? As you've noticed (and depending on your luck) some are super susceptible to vibration.
EDIT: Nevermind, I see it is what Pete is offering now. Guess I better order one of these puppies! 😀
