Thomo said:The i/v stage i was looking at was fully discrete🙁
Hi Lee,
At the bottom of the Pedja's page headed "Pedja Rogic Audio Pages are no more," there is a small box labelled "files." If you click on that it will take you to some sort of archive or "index of files." There is a sub heading "tda1541a." Again click on that and it will take you to some schematics, including one labelled "I-V-discrete.pdf"
I'm not sure if this is the i/v stage you were referring to, because I am having trouble reading the text of the pdf file. Seems to be incompatible with my Mac. However, the schematics show up.
The direct link to the "Index of /files/tda1541a" is http://www.pedjarogic.com/files/tda1541a/
Joe
Thanks guys. I found it earlier after reading through his page.
I may well have a play about tonight, and see if I can improve my output section.
Cheers, Lee.
Cheers, Lee.
CD650 Philips
I have tested on browndog adaptor AD825A+LME49710+22K resistor in ouput IV stage and soud amazing (vs marantz cd 50se fine tuned and cd160 nos tubed).
http://www.diyaudio.com/forums/showthread.php?threadid=92994
In the second stage opa2604.
will be send a photos of the mods.
bye
bye
Distortion,
That sounds interesting, I'd love to see pictures. Personally I can't stand OPA2604 (I/V & buffer) because of the harsh, false sound. Perhaps in your application it doesn't sound like that at all.
Lee,
Nice one, I'm glad it was found.
Simon
Lee,
Simon
I came home yesterday to find my CD650 dead. The Super Regulator on the SAA chip is outputting zero volts. It must have over-heated. I will just downgrade it to a 7805 for now!
Simon
Simon
L M A O
Noob
edit: They really do get hot those regs don't they? I added one 7805 to power the digital board of a cd94 and used a good sized heatsink (same as you get on Audiocom Invisus), and it's running too hot to touch!
Noob
I think the superglued heatsink was not well enough attached (thermally). I will put a 7805 on there and then move up to an S Power if the chip wants one. I'll see how it sounds on a 7805 before making that move.
Simon
Simon
SimontY said:I think the superglued heatsink was not well enough attached (thermally). I will put a 7805 on there and then move up to an S Power if the chip wants one. I'll see how it sounds on a 7805 before making that move.
I used a LM317T based "RayReg" (from the Marantz thread) on the SAA7220 in my Rotel RCD965BX. I used a PCB vertical mount TOP-3 heatsink with largish fins (4.5 degree C/W) and it still got very hot. I then glued on smaller heatsinks using "Arctic Silver" heatsink epoxy (for computer CPU coolers) until the thing cooled down enough. It now runs at 35 degrees C and seems to be happy at that, although it looks a bit of a mess with all those heatsink bits stuck together.
Joe
That chip sure sucks some juice then! Thanks for the ideas, I'll get something worked out 😀
Simon
Simon
In a CD85 I upgraded I used a copper 13.2 C/W sink and a ally sink bolted together with compound when using an SPower, this ran @ 38 deg c with the lid on on the same chip, iirc the voltage headroom is greater in the cd85. The SPower ran very hot without the sink and long term I did not fancy leaving it like that.
I was tempted to bolt the reg to the ally chassis but wanted the reg as close to the chip as possible.
Brent
P.S I don't recommend bolting the reg to the CD650 chassis
lol
Brent
Originally posted by philpoole Its fairly easy to knock up a simple op amp IV - just make sure you don't forget the capacitor in parallel with the resistor in the feedback path - or you might get oscillation and heat and distortion. (but don't worry, it can be simple to do). Also, a servo might be pushing it, but instead, a current source into the IV stage can be used to bias the output so it has zero DC offset, and thus no capacitor required. The DAC output swings from 0A to -4mA (so the output swings from 0v to +6.4v, so if you add 2ma to the input, then the centre point will be output at 0V (so -3.2 to +3.2v). I guess it can drift with temperature (hence a servo would be better), but its probably negligible.
I think the DAC swings 2mA and draws a constant current of 2mA with can be nulled with a 2mA Constant Current Source like in the Pedja Rogic DAC.
Hang on, I think that's what I said ?!
rowemeister said:P.S I don't recommend bolting the reg to the CD650 chassislol
Oh does cheap plastic not have high thermal conductivity then?
I have to do a bit more work on getting my SAA7220 to run cooler and there is not much room left in my Rotel for more heatsinking. The ambient temp in Perth today is 30 deg C, and its only just starting to warm up for summer here. 38 - 40 deg C is common.rowemeister said:In a CD85 I upgraded I used a copper 13.2 C/W sink and a ally sink bolted together with compound when using an SPower, this ran @ 38 deg c with the lid on
I am wondering whether a lower supply voltage into a low drop out 3 pin reg will run cooler. The 317 based "Rayreg" I am using is currently supplied with a 12V. Perhaps I can exchange the LM317 for something like LT/LM1086 and use a 7-9V supply?
Another alternative is mount a large heatsink on the back panel, but the SAA7220 is near the front panel on my Rotel and so the supply lines from reg to chip would be about 250mm long. Like you, I want to mount the reg close to the chip, so fiddling with the heatsink or the regulator type and supply voltage seems to be the deal, bearing mind ithat I have a tight budget.I was tempted to bolt the reg to the ally chassis but wanted the reg as close to the chip as possible.
Bearing mind ithat I have a tight budget, any other suggestions are welcome.
Joe
You should be able to get enough drop from 9v for a 5v regulator. 7v might be a bit low, but 9v is more than enough. I have a 7805 powering my SAA7220, from 9v, and it doesn't have a heatsink. That doesn't necesarilly mean it doesn't need one! But, at least it isn't too hot to touch, and it hasn't cut out.
30 degrees, going up to 38-40! Don't rub it in! 🙂
philpoole said:You should be able to get enough drop from 9v for a 5v regulator. 7v might be a bit low, but 9v is more than enough.
Hi Phil,
OK. I can try 9V. I already have a spare unregulated 9V rail from the original Rotel transformer (I have installed another 5 to feed the 15 regulators), so I can try that and see if the 317 based reg runs cooler, although it will have to wait until after Christmas now.
I suppose it sounds good when you are in the snow, but it starts to be too much of a good thing after a whole month of it. Would you believe that our Super 14 Rugby season starts in a few weeks (teams from Australia, South Africa and New Zealand) – right in the early to middle part of summer. They have to put the players in an ice bath at half time to cool down an some need fluid replacement by IV drip. Rugby used to be a winter sport where we froze at half time and spent most of the game sliding around in the mud.philpoole said:30 degrees, going up to 38-40! Don't rub it in! 🙂 [/B]
joe
9v in, 5v out, 200mA for the saa7220 = 0.8w dissipated. That's OK for a 317 alone (max is about 1W continuous but check the datasheet for any temperature derating) and a small clip-on heatsink will help a lot.
The point when you can only just bear to touch for 3seconds is about 55-60degreesC, that's a good maximum for long term reliability (remember the junctions inside the package run hotter!)
I did wonder about using a pre-regulator to bring the supply voltage down a bit to stress the SAA's 5V regulator less.
I should have time to replace my reg today.
Simon
Simon
That works well, as can simple brute-force RC using a resistor. Try, say 10ohms / 10uF before the reg. TIt makes for a nice filter at 1.6Khz, chopping HF noise down before the reg, and will drop about 2v / disspate 0.4W. Use a 2W metal film resistor.
Oh, you can use more capcitance here too; it's not remotely critical. Using say 100uF pushes the 'knee' down to 160hz, which gives the reg slightly less line regulation to do of course.
- Digital Source
- Philips CD650 mods
