• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
PhiDAC hex kits with pre-built filters
Stage 2 voltage
These are my measurements
L9 /1R 17 mv
C57 3.56v
R56 4.8v
R65 4.6v
R70 4.6v
It is a bit higher than expected at R56.
The 17 mv across L9 /1R is ok without filter attached?
R56 is intentionally set to a slightly higher voltage than the other two so you're good. When an I2S clock is supplied that 4.8V will fall to be similar to the other two.
Yes 17mV is absolutely fine without filter attached. You're good to solder in the opamps.
TP7 is the point of interest now, along with TP1. I see a splash of solder between R55 and R68 which is a concern.
TP7 at 7.8V is promising, not very different from TP6. TP9 is still at 10V? Check voltage drop across R66 to see if the AD744 is functioning correctly - it should be about 5mV.
Got music! No hum.
I gives me great satisfaction as this project involves the most amount of smd soldering in my diy hobby.
The handholding by Richard is very comprehensive, prompt and l am very impressed.
I was interested in this project right from the beginning of the discussion in long lingdac thread.
Thank you to Richard and several others in the forum.
