• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
PhiDAC hex kits with pre-built filters
Which TP? TP9 ? R66 voltage drop seems too low so presumably some parts of the AD744 are being de-biassed.
In order to be sure the problem's around the AD744 I need to know if TP7 is still ~5.5V? (that's measured with the filter plugged in).
Based on your AD744 voltage readings the opamp is working fine. The puzzle is how its possible for pin2 to be 0.64V when TP7 is still 7.9V. Best guess is a short across one of the caps C47-C50. Or the opamp's failed in such a way as to put a low voltage on pin2.
C49 may be the culprit
Replaced AD 744. Rather scary procedure without hot air gun. Have to use 2 soldering irons.
Problem persists after AD744 change. The pins of the op amp is dirty and refuse to bind to solder. Have to use blade to scrap off the dirt.
Direct attention to C47 to C50.
Remove c49 and immediately TP 9 measure about 2.5v
I think l need more practise soldering smd.
It sound very very good. Hearing microdetails that l wonder whetherit is my imagination or not.
When music is playing, l hear random low level noise such as switching on and off individual tracks in a multitrack recording. I am uncertain whether this is in the recording or a distortion.
I don't hear this distortion when l pause or stop music. I am using mediamonkey or VLC player
