Pete Millett LR phono
Pete used the chassis as common ground. He also used a PSU but did not attach the safety earth to the chassis and mentions the risk.
With a battery you don't have mains in the chassis so this option seems easier.
For my latest build I did the same as you with isolated RCA's
I read all the risks and warnings Pete spelled out on his project page which is what really prompted my question. I’m planning to try battery power and wanted to build the Silent Switcher, currently unavailable in the store. Are you running your battery direct or doing some form of regulation?
My first build used a SilentSwitcher powered off a battery pack but I no longer have that build.
Another option is to run it directly off of 2x SLA batteries like Dave from Landfall.
I like the convenience of my latest build with the VRDN: there is no mains or transformer in the chassis, the PSU is extremely quiet and you don't need to worry about charging or replacing the battery
Reactions: pfarrell and glenv6
I finished my LR phono preamp last week and after listening all week, I'm very impressed. DC offset was set to 0.00mV after 1 hour, very easy procedure after reading this thread. I still think my Salas UFSP sounds better, however, it may be the turntable/tonearm cartridge combination.
UFSP: Thorens TD321, SME 3009 MK3, Shure V15VxMR w/ JICO SAS neo needle
LR: Thorens TD125 Mk1, SME 3009 s2 improved, Sumiko Blackbird MC High out
I've always wanted a phono preamp using batteries, so I built this with two CA1212 AGM 12v 1.3Ah batteries. I used a 4PDT switch from Parts Express for the ON / OFF/Charge, and a 1/4" phone plug for the charge port. My Battery Tender Junior works great on my Motorcycle AGM batteries, so this is my charger set up for the LR. The difference in cost from batteries to a regulated power supply is a tremendous incentive to use the batteries.
I am also a satisfied user of pmillett LR phono stage. I did use a slightly different BOM
The following component are changes from the recommended BOM
1) Nichicon MUSE for all the power filtering capacitors
2) Talema toroidal power transformer
3) Vishay Z-Foil for R27 and R28
4) UP OCC silver and copper cabling
5) Burson V6 Vivid opamps
I tried both AD797 and Burson V6 Vivid opamps and settled for Burson. AD797 was fatiguing for my headphone setup
Did you have to make any changes to the circuit using the Burson V6 opamps to adjust DC offset?
Built two of these so far. Had an issue with hum on both of them until I used a separate power supply chassis. Now they are quiet as a moose, um er, mouse. Used slanted 'boat jacks' on the back. A little more work but can take the strain of f of some IC cables.
Nice build.
Can you post a drawing of your battery wiring?
I want to try batteries on mine, feeling a bit daft about how to wire it.
Ed
I just made adjustment to DC offset.
When I install one BursonV6 vivid opamp on each channel with an AD797, the lowest DC offset I can adjust to is 240mV. When I use all four BursonV6 vivid opamps, the lowest DC offset I can adjust is 416mV. Also, the change in DC offset is only about 80mV total.
Yet when I use the AD797 opamps, I can easily adjust DC offset on each channel to 0mV.
I even tried to use the AD797's in the first stage and the BursonV6 in the second stage, no change in DC offset behavior. I did send Burson an email regarding my issue, don't expect a response for a while with the holidays and all.
There’s no mystery. AD797 has a function on pins 1+5 that the Burson doesn’t, (offset null) and this is an important part of the LR phono circuit, because it doesn't have a capicator in a location where every other opamp phono would have one. (Because LR only, obviously.)
Reactions: Ixnay
Here's my experience so far.
AD797 with PSU : DC can be adjusted very close to zero and very close to equal for both channels.
BursonV6 with PSU : DC can be adjusted near to zero and very close to equal for both channels.
BursonV6 with battery : DC was not able to be adjusted near to zero but can be adjusted close to equal for both channels.
AD797 with battery : Not tried
What the difference you are hearing between the original OPAMP AD797 vs Bursons?
I'm going to build my LR Phono preamp in one chassis, and I'm investigating some layout possibilities.
Given the dimensions of the chassis, the transformer, and the PCB boards; I think I have two layout possibilities for which I have made the drawings below.
Which one do you think is the best option?
Layout 1
Layout 2
