there is a magic number , as Papa clearly wrote in XA25 manual - everything works as welding gig up to 10A , where protection kicks in , and you need to cycle power off/on to reset
so - if you need more than 10A (hardly) , go for more muscle
however , Maggies are (at least to my knowledge) having impedance nature of dumb resistor , with peak somewhere down , and that's hardly hard to drive
so , your choice is maybe hard , but certainly not to be puzzled about current demands
I remember enjoying SMG with 1.5W toob SE ....
Thanks for the replies.
The F5T article says 38A into .1 Ohm. That's seems pretty incredible to me. I assumed that's all things being perfect, best case scenario.
The fuse will give out way before that, right? I mean I only have a 10A line anyway.
I suppose there needs to be a sanity check for commercial gear too. Not so much for DIY. 🙂
Hey man, if the F5T v2 can drive it, then I'll try it. 😀
I read in the XA25 manual there is current limiting at 10A so perhaps you can get more out of the F5T v2.
I heard a set of Maggies (the big ones, probably 3 series) driven by a big McIntosh amp...probably 250w or so. It wasn’t that loud and it was burying the needles on the front meters of the Mac. Didn’t particularly sound that great either. I feel like it was probably a lot louder than I felt it was, kind of like the way headphones can keep you turning it up without really knowing it.
That was the day I learned magnepans were not for me.
Those are the kind of reports I'm talking about.
Not necessarily the amps fault, but a bad pairing can ruin your day.
with (at least smaller) Maggies problem can't be so much in current domain , as can be in pure voltage (read - Watts) domain
to be clear - due to benign impedance modulus , all you need is decent amp , with enough watts to cover simple calculus - watts in function of speaker efficiency
I agree with ZM. Based on what Z data I've seen online they should be fine with f5t for sure and I'd assume xa25 as well. Actually as I am making a lot of different speakers I tried FW amps with speakers with all sorts of Z and sensitivities and can tell you that i found only two were loosing their performance a bit: Aleph J and J2 (clones in my case). That being said if you listen to some simple music you might never even notice that. BTW, you can always measure Z of your Maggies and see for yourself.
I just received Stereophile Special Issue 61 which contains a review of the XA25 by Herb Reichert. I found nothing online about this review.
I found in a forum this comment, hope it is correct.
"John Atkinson's measurements showed that the XA-25 greatly out-performed its stated power ratings significantly, indeed. It's specified power out put is 25 watts into 8 ohms and 50 watts into 4 ohms. Atkinson's measurements were 80 watts into 8 ohms and 130 watts into 4 ohms.
Pass Labs is always quite conservative in their ratings to begin with, with the XA-25 this little amp in size is quite the powerhouse hitting way above its ratings."
and ....... did he found 300B in it ?
No, but he made quite an effort to like it and even brought in a mythical friend who does like it. That's before the unfortunate comparison to a cheaper Chinese integrated.
Somehow i doubt HR is the right person to review SS equipment.
I got it ( article ) from my little bird 😉 ....
I know H.R. writings all the way from Sound Practices ......... he's notorious Romantic , as I am , regarding equipment sound
of course that (any) 845 based amp will be lush comparing to Laboratory Grade amp , as XA25 obviously is
Catch 22 is that Pa made small fun one , while few other (so called or real ones) Lab Grade amps are presented as something bigger than life itself
frankly ....... I know how much of challenge is to make XA25 iteration ( myself being on iteration No. 102827772 .... and counting) but it's really big question do I need amplifier as that one
disregarding fact that I really do not need more amps
Kimmt a Vogerl’ geflogen,
Setzt si nieder auf mein Fuß,
Hat a Zetterl im Goschl
Und vom Diandl an’n Gruß.
in English:
Came a bird 'flown,
Sit down on my foot,
Has a note in his Gob
And from the girl an'n greeting.
in English:
Came a bird 'flown,
Wow .. what a review! And to impress so thoroughly a 845 smokin audiophile🙂
I don't anyone will get upset if i attach the concluding paragraph here...
Well done to Nelson and the gang at Pass Labs
I'll need to reviews this amp, just to be sure.
Send review sample to:
Mike R.
XXX XXXXXX XX
XXXXX XXXXXX, XX XXXXX
Very Happy News! Congrats! 🙂
Mike R.
XXX XXXXXX XX
- Pass XA25?
