Pass XA25?
there is a magic number , as Papa clearly wrote in XA25 manual - everything works as welding gig up to 10A , where protection kicks in , and you need to cycle power off/on to reset
so - if you need more than 10A (hardly) , go for more muscle
however , Maggies are (at least to my knowledge) having impedance nature of dumb resistor , with peak somewhere down , and that's hardly hard to drive
so , your choice is maybe hard , but certainly not to be puzzled about current demands
I remember enjoying SMG with 1.5W toob SE ....
Thanks for the replies.
I read in the XA25 manual there is current limiting at 10A so perhaps you can get more out of the F5T v2.
The F5T article says 38A into .1 Ohm. That's seems pretty incredible to me. I assumed that's all things being perfect, best case scenario.
The fuse will give out way before that, right? I mean I only have a 10A line anyway.
I suppose there needs to be a sanity check for commercial gear too. Not so much for DIY. 🙂
Hey man, if the F5T v2 can drive it, then I'll try it. 😀
I heard a set of Maggies (the big ones, probably 3 series) driven by a big McIntosh amp...probably 250w or so. It wasn’t that loud and it was burying the needles on the front meters of the Mac. Didn’t particularly sound that great either. I feel like it was probably a lot louder than I felt it was, kind of like the way headphones can keep you turning it up without really knowing it.
That was the day I learned magnepans were not for me.
with (at least smaller) Maggies problem can't be so much in current domain , as can be in pure voltage (read - Watts) domain
to be clear - due to benign impedance modulus , all you need is decent amp , with enough watts to cover simple calculus - watts in function of speaker efficiency
I agree with ZM. Based on what Z data I've seen online they should be fine with f5t for sure and I'd assume xa25 as well. Actually as I am making a lot of different speakers I tried FW amps with speakers with all sorts of Z and sensitivities and can tell you that i found only two were loosing their performance a bit: Aleph J and J2 (clones in my case). That being said if you listen to some simple music you might never even notice that. BTW, you can always measure Z of your Maggies and see for yourself.
I found in a forum this comment, hope it is correct.
"John Atkinson's measurements showed that the XA-25 greatly out-performed its stated power ratings significantly, indeed. It's specified power out put is 25 watts into 8 ohms and 50 watts into 4 ohms. Atkinson's measurements were 80 watts into 8 ohms and 130 watts into 4 ohms.
Pass Labs is always quite conservative in their ratings to begin with, with the XA-25 this little amp in size is quite the powerhouse hitting way above its ratings."
I got it ( article ) from my little bird 😉 ....
I know H.R. writings all the way from Sound Practices ......... he's notorious Romantic , as I am , regarding equipment sound
of course that (any) 845 based amp will be lush comparing to Laboratory Grade amp , as XA25 obviously is
Catch 22 is that Pa made small fun one , while few other (so called or real ones) Lab Grade amps are presented as something bigger than life itself
frankly ....... I know how much of challenge is to make XA25 iteration ( myself being on iteration No. 102827772 .... and counting) but it's really big question do I need amplifier as that one
disregarding fact that I really do not need more amps :rofl:
Kimmt a Vogerl’ geflogen,
Setzt si nieder auf mein Fuß,
Hat a Zetterl im Goschl
Und vom Diandl an’n Gruß.
in English:
Came a bird 'flown,
Sit down on my foot,
Has a note in his Gob
And from the girl an'n greeting.
Wow .. what a review! And to impress so thoroughly a 845 smokin audiophile🙂
I don't anyone will get upset if i attach the concluding paragraph here...
Well done to Nelson and the gang at Pass Labs
