@ClefChef, here is an interesting project using WM8740 with Lundahl output transformers, however it gets expensive as this will need 4 x Lundahls so the question is how can I connect only one transformer per DAC to sum up the dual-differrential output ?
Interesting also to see the use of oscon caps on the analog bypass section.
USB DAC 1 - Hi-Resolution System
I like Andrea's designs a lot, I built AD1865 DAC (similar to DAC END). In my experience transformers (used with tube stages or without) tend to sound better than coupling caps - better dynamics and super delicious bass. However, good sound comes with a price...
Hi Guys,
Does anyone else notice the Dac Magic plus has a very audible high pitched ring from the unit around the area where the power supply plugs in?
Mine was initially so bad I thought there was something wrong with the unit
However, it turned out to be totally unrelated to the issue I'm having, which is (as a beginner) proving very difficult to isolate for me. I'm not sure if this is the right place to post, but it seemed tidier than starting a new thread.
I've lost the right channel of the RCA. I haven't tested the XLR, but I'm after some advice where to start out! The input capacitors all hold charge, I think one of the output relays (RL3) is kicking in due to an issue in the audio circuit somewhere. Although I have a DMM I've only used it for temp measurement in coffee roasting so need to read a few guides again on how to measure caps - no access to a signal generator & scope here! While I have the service manual (thanks for sharing sonic!) I don't have a printer and the last thing I want to do is burn more of it out by shorting pins accidentally on the back side of it.
thanks,
Portll
PS. I'm new here, hi 🙂
A quick question, can I use both the RCA and XLR(will use adapter) output on the same time?
Will connect it to a Headphone amp and a receiver.
Using these adapters:
yes you can.
Having said that, if your headphone amp, like the musical fidelity m1hpa, has a pre out, and compare the two ways, and as the balanced output is better in nearly every way.
Hi aptsys, here is the setup with the AD797
http://www.diyaudio.com/forums/digital-line-level/142184-opening-new-dacmagic-41.html#post2890834
All 4 of them feel equally hot on the browndogs.
Assuming in this setup, 15mA go to the SRegs + 2 x OPA2120 and with
1) R400 at 100ohm I measured 5.86 voltage drop which gives 11mA per opamp
2) R400 at 56 ohm I measure 3.84 volatge drop which gives 13mA per opamp
hope that clarifies the situation
What are the factory values for R400 and R401?
The factory ones are 56 ohm 2W carbon resistors. I measure 72C on the AD797 using an infrared thermometer which I think appears to be within its operating range.
most of the dac chips today use voltage output instead of current output,so the iv convertion is done internally.the wolfson has a negative signal as well as a positive signal coming out of the dac,your balanced out is already there,just use it.for unbalanced use only the positive or + signal for your output,one for each channel.use a really good cap here,you could use a 47uf silmic II or nichicon zk,bypassed with 1-2uf polystyrene or polypropylene.no additonal low pass filtering is needed!!!!!!!go from dac output to rca jack.once you have done this you will never go back to op amps.you already have 2 volts output from the dac to drive anything.enjoy.p.s. make sure you cut the trace going to the rca jack.
Has anyone ever tried this?
Have not tried this, but it should not be any technical problem to do this. There are many DAC schematic's using the output of the DAC directly.
The question is: Why would Camebridge spent money on all the extra components: power supply; 4 additional opamps; etc..... ?
I don't say Nickojko is not right, but I am just asking........
Here is the upgrade I performed on the DACMagic after gathering all info on this forum
1) Replaced all capacitors for Panasonic FC Capacitors
2) Replaced the 7805 for NewClassD UWB power regulator
3) Replaced all NP capacitors for Panasonic NP capacitors (higher voltage)
4) Replaced the unbalanced opamps (4x) for LME 49720
5) Bypassed the output caps (shortened), after measuring the ouput = <3mV
6) Disconnect the RCA outpput and reconnect to balanced +output to bypass the last OPA opamp
7) Higher the capacity of the "Villard" capacitors from 470/220 to 680/470 to allow higher current flow
8) Add additional 220uF capacitors to 15 volt outputs
9) Replaced the power adapter for a 9VAC 36VA to overcome the heat problem (7X15 regulators)
Incredible improvement of sound! Compared to original unit, my sister owns one.
DacMagic, and DacMagic Plus
I own a Dacmagic, and have followed this thread--The only mod I did was to bypass the output caps ( I had only 1.7mv offset, and I use the balanced outputs) and I replaced the AC supply with an Audio Advisor Pangea supply--just bypassing the caps made a huge difference--thanks for the info in this thread😀, the new AC supply was better also (larger soundstage).
I was thinking of purchasing a DacMagic Plus (I have a few 176.4 and 192 files and DVD audios) and wondered if anyone has measured the DC offset in the Plus unit, and if the same cap bypass would work in the Plus version? It has the same DACs but I think the output opamps are different. I can't use the new supply as the Plus uses a DC supply. (I can't find a thread on the Plus)
I think what you're hearing is the induction coil, somewhere in power supply, oscillating at high frequencies. It is usually caused by lose ferrite core inside the coil. Determine which one is ringing (do it with a long piece of rubber tube inserted in the ear). You may have to disassemble the coil and put some glue and/or shrink tubing on it.
I had a ringing coil in my DacMagic, i dealt with it by filling it with epoxy - dead silent now.
Is it possible for someone to explain to me where the coils are? I have searched high and low, but sadly I am too much of a beginner.
Love this thread, after receiving my second hand dacmagic, I quickly realised I had a coil whine...
cheers.
Picture in post # 490. Upper right area, the two round parts with a white dot on them are two obviously visible ones.
@Mooly,
Thanks for the quick reply! My first diy fix is on the way! No clue yet how to open them up, but I think I'll find a way 🙂
You may not be able to open them, the best you could hope for would be to remove them and fill them with epoxy glue from the bottom.
The outer part on those looks like ferrite which is very brittle.
Thanks for the info, I will try all this during coming weekend. Another questions pops to mind. When the coil is removed from the PCB, filled with hot glue/epoxy. how do I attach the coil back again to the PCB. I have read that hot glue would be possible or is soldering a prefered method?
- Digital Line Level
- Opening the new DacMagic????
