Open source Waveguides for CNC & 3D printing!
Thanks a lot for the printing advices.
I understand that I the range of tweeters addressed, the SB26 seems to be the one with the "best" quality/price/usability ratio to discover waveguides. Is it correct or should I also look at other references?
This would be for a 2.1 system, to listen music in a 20m2 room at 1.5-2m distance.
Jmf
Building on this, what is the optimal shape of the dome for direct coupling to the throat?
There isn't a simple optimal, the size, shape and curvature of the dome and surround have a big impact on how the waveguide needs to be designed to get the best overall response. Tall domes like the Bliesma aluminium versions create a difficulty where the height of dome relative to the surround can cause off axis cancellations high in frequency. Soft domes are difficult to predict as they separate out to have different parts of the dome radiate in different ways as the frequency changes. Modelling methods that assume pistonic motion with rigid membranes won't be able to capture this effect.
The SB26 shape is a good compromise that works well (as can be expected) on just about any profile I have tried it on.
Reactions: 1 user
@DSP_Geek
That's true, this is well described in Borwick's Loudspeaker Handbook (there are others, but this is one I have quick acces too atm). Page 78, 3rd edition.
However, I wonder if that really matters for a waveguide?
The dome material basically only effects resonances as well as frequency response.
Although there are other tricks to get that right. (with all of them having advantages and disadvantages)
Everything before the first material resonance is just pistonic region.
For softdomes, this can be a little less well determined sometimes.
(which can also be seen as an advantage at the same time)
Borwick glances over that part a bit, but Eargle describes those things very well in his Loudspeaker Handbook.
Brandon,
Thanks for your response and positive comments. And of course, thank you for your efforts in getting these WG out to the DIY community. I look forward to buying you a coffee soon. :)
These were printed by Zelta3d of Singapore, and the finish is dyed. I ordered through the Craftcloud platform. Order process was easy, and delivery was quick.
Could you pass me the plan files for printing the SB26 WG and the URL of this people in Singapore?
