Official LYNX Power Amp builder’s thread
G'day
I don't think it's very good using a simple current limiter. A dual slope VI protector is no more complex really and provides more in the forward sense and much less in the reverse sense so difficult loads don't cause damage.
the chip is quite heavily loaded which would worsen its distortion.
I wouldn't use LF356 or LF357 with this - they are awful sounding even lightly loaded.
mike
sorry for my stupid questions
yes,If we bent all the pins then was obtained by 14mm.
But if we were bent the pin from his starting point, the pins was still being easy to be broken.
can i use 2x47uf polar in series to replace the original 22uf non polared?
for 13K resistor, can I series 12K with 1K?
very hard to find 13K resistor in my town
I will continue to used lf356 and 1n4148 to replace BAV21
Thank's
Hello,
CRT .......
Use LF356 its has a good sound believe me.
better to place the driver in main heatsink .............Its hottttt or you in trouble dealing with a big driver heatsink.
Jan,
The difference between Lynx 2.2 and lynx 3 are in some resistor value, added C in feedback, and diode paralel with base and colector in first Transistor stages, do you mind to explain why ?
1. you use this diode ? ( honest I cant Find any difference with my scope and ears)
2. what the benefit for C in feedback loop?
crt;
Yes you can use 2x47uF in series (will not fit the pcb, but it will work)
If you replace the 13K (R105&106) with a 12K, you may want to reduce the 1K (R107/108) to app. 850R
Rembulan;
The main diff between v2.2 and v3.0 is that now the output devices are on the pcb + some miner tweaks.
The diodes d107/108 acts as soft clipping when VAS stage reaches it's max output.
C109 in the feedback is just an option for providing some extra feedback at higher frequencies.
CRT
Eh CRT di surabaya dimana bisa beli OPA627 75rb asli ngak.
Jan, I remember 30 years ago when I started make tubes amp every day I try a new tubes I got from flea market now I hunt to every local shop look for a single opamp and try it in my Lynx. Tomorrow I want to try something different perhaps change the driver from BJT to MOSFET. Thanks to made a new addiction to me
Thank´s Jan
Kapton 0,05mm, 1,00 degrees C/W
Silicon 0,75 - " -
Silicon adhesive 0,30mm, 0,40 - " -
Aluminiumoxid 3,00mm, 0,30 - " -
These differences is nothing to bother ?
I belive you have proven the silicon to work with this amp.
ELFA 75-646-77 ? The adhesive one.
regards
Re: CRT
Rembulan said:
Eh CRT di surabaya dimana bisa beli OPA627 75rb asli ga
Permisii Pa Rembulan, Pa Crt.. buat cari High End Spare part dari resistor 0,5 w dari harga Rp: 500 ampe yang berharga Rp: 50.000 pcs, dari ic ampe tabung, black gate capacitor dll ada di www.langsungjadi.com malah di surabaya ada tokonya kok? call Pa, Alex kualitas Barang tergantung isi dompet kita trus Pa Crt kit2 yang mereka jual juga ga kalah loh ama produk luar...
OK selamat berburu Spare Part ya...
ACD said:
I don't know if it's a case for a moderator to comment on these personal comments between crt and Agus Widarto, however if we all should find this thread helpfull, then please write in english......
Oh My God,,, Sorry Mr Jan, don,t miss understand i'am just to tell to my friend crt and rembulan, were thy can to find spare part for build LYNX Power amplifier ( OPA, NP capacitor etc ) I cant write werry well in english so i write in Indonesia language Sorry Mr Jan?🙁
Thank and GBU!
regards
