non-profit ver.3 TDA1541a DAC for limited budget diyers
Hello Thomas !
I understand, no problem !
My order was :
- AC v3 kit full assembled wth CS8414 with pc isolate power trans 50hz 220V 16V-0-16V
- 14 MKP matched caps
- EMS
Total : USD 169 + 1.5% paypal charge : 172$
Paypal number was 2WV05450UJ9459710, transaction has been done on 20 july.
Shipping adress is Nicolas Dupont at Carrières-sur-Seine in France.
If you need more info, let me know !
Thank you again,
Regards,
Nico
Hello Thomas,
No problem for this, I know you have a lot of work !
The address in your last message is correct.
Sorry, I don't know what is "double crown chips", can you tell me more about this ?
Can you confirm power trans is included in the package ? Otherwise I'd need one, tell me about extra cost about it.
Thank you,
Nico
hi Nico,
your rice was include the power trans already. But according las time experience, may be the postage will increase a little because the EMS to europe was expensive than in asia.
USD7 was extra charge for asia only.
This is the broups buy TDA1541AS2 chip, THis is the best 1541a chip in the world. Due to my DAC was only use one chip, if U lke one, U can considerate to get one. USD80 for one chip only. Many diyers also order 1~2chips already, some order 6~12chips.
If U like one, I can put into the parcel & post together with U tomorrow.
forgot to tell U, s/n of the EMS parcel was EE696709002hk.
thx
thomas
Hello Thomas,
For the postage, you asked me for USD 13.5, tell me if you need more.
Thank you for explaination about TDA1541AS2 , but I didn't read any feedback with this chip used with this dac... Does it really improve sound quality ? Is there something else to change when plugging this "S2" chip on the board ? (I'm not good in electronics stuff !)
Just to confirm : your ultimate version is not yet ready ? I could be intersted. If it's not the case, this standard version is of course OK for me, but I can wait if necessary 🙂
Sorry to be boring, I give you my answer as soon as you give me more information 😉
Thank you,
Nico
tube-lover said:
hi rtd,
your case must be the pri winding was wrong connection.
this is isolate power trans. In your case. I was worry will,be damage.
thx
thomas
So I use the wiring depicted by Thomas and all is Ok. The power transform stills ok despite of the overheating when wring was wrong.
So know i will let all burnin' for a few time
Thx again for support.
Hi folks,
After a long and very pleasant holiday in Turkey, I returned in a cold and rainy Netherlands. But also... finally a chance to try my brand new TDA1541A DAC. So yesterday evening it was time to test the PCB.
I found a couple of 2x15Vac transformers that measure 17.5 Vac. They can only deliver 0.5A so I decided to parallel the secondaries to double the power. So I use two secondaries of one transformer for each supply side. I decided to remove all the add-on boards for the first test. After power up the RCA LED was green, good news. After measuring the PCB it turned out that the -5V connection between the two PCB's was not good. So I resoldered that one. Then I put on a S/P-DIF signal. Now a red light. I found a high DC voltage on the output, this was not good. But now it is away. After a bit of messing there was sound!!! 🙂
I must admit that I bought this kit mostly out of curiosity and because I was looking for a nice audio project. I was a bit sceptical if this kit really would give high-end sound. I currently use the Hercules 16/12 soundcard with internal DAC (external soundcard). I was very surprised to hear that the DAC is very musical. Actually it seems to be better than any DAC I have here in the house. Very dynamic & emotional, and smooth & sweet at the same time. Lots of detail and good focus. Very nice to listen to!!! I should do more comparisons to find out how good it actually is. But at this moment I am very satisfied... (I listened music to 2:30 this night).
Later, I tried the filter board. I must say that the connection is not so good. Sometimes I hear cracks. I'll have to see how I can improve this. I also tried the OPA627 opamps without success. No sound. Do I have to change the JP6 jumper to make this opamp work? Any other ideas?
Another question: does the $80 dollar for the S2 chip include postage to Europe?
And thanks Thomas for your nice kit!
I look forward to try to get even more music of it...
Bye,
Fedde
hi fedde,
very thanks for your feedback.
let me share some imformations about the matching of parts & chips.
0.1uf coupling caps use Wima + Philips 5534/AD797= balance & musical.
0.1uf MKP coupling caps use Wima + OPA627= little bright, more detail but less musical, fit to vintage equipment because less dim & soft sound.
0.1uf MKP coupling caps use philips+ Philips 5534/AD797= balance & musical, very sweet sound but little less detail. ( advise)
0.1uf MKP coupling caps use philips + OPA627= little bright, more detail but less musical, same as wima but slightly less bright than wima, same fit use with vintage equipment because less dim & soft sound.
0.1uf MKP coupling caps use Epcos + Phiulips 5534/AD797= sweet, balance, good focus, more air & good bass. better than all of the coupling caps that I use before.
0.1uf MKP coupling caps use Epcos + OPA627= bright, too detail less musical, brighter than wima. Very suitable to slow & dim , less air vintage equipment.
So In here I will strong advise use first priority is Epcos caps, secondary will be the Philips MKP caps.
second is the sometimes cracks sound of the signal input, since this is the non-profit version dac. I hadn't too much source money to improve. But.......... don't worry. Ultimate ver.3 is coming.
USE MCU to control the the power supply delay several secs. when U switch the power,No crack sound.
MCU with the relay to control the source input to lower the cross effect between different input jackets. espcially the XLR was real balance input, seperate the Nano pulse trans input stage with relay. total 7 relays per DAC.
1541A can chose single chip operate or choose parallel chips to operate. I still advisae Use one the best AS2 chips. If use two chips I suggest use the another coming full balance DAC (1541A).
There had a switch on the facelet tunning for the source input.
two USB receiver, when U play CD, USE the best PCM2906 will better, if U use DVD audio or playing DVD music disk. U can chnage to another USB receiver. CM106L. This different Chips will interchangeable in the coming Ver.3 ultimate ver.Dac in modules format.
Since PCM2906 was USB1.1 only but will enough for standard CD in good performance. CM106L had USD2.0, large brandwidth will playing more smooth in DVD. This USB sound card will output SPDIF signal to CS8414 in 16bits, so 1541a can work. Diyers can use footbar to control the music signal. in WAV or APE. U can save lots of the CD into your hard disk. Seperate of power supply of the USB can lower the noise, more silient.
the display of Facelet signal selection board can upgrade. standard is LED to show the source input, but if U like, can upgrade into LCD or VFD version later by yourself.Very easy to exchange, plug & play only.
sample will see on the middle of augest.
All were full assemble & test version. User friendly, plug & test, enjoy music simple DAC.
P.S. use TDA1541AS2 will improve the background music more silent, higher S/N ratio. more detail & improve the 3D focus image.
USD80+2=USD82 was use regmail post world wire. Not need anymore charge now.
pls considerate.
I will not remain too many pcs of chips on hand. since japan directly order 50 pcs already.
this is japan directly order parts detail.
Hi thomas,
I buy 50 pcs of 1541AS2 chips. But, I am first time to transfer money to Hong Kong.
Therefore, time hangs. I want to transfer money tomorrow.
Regards,
NoXCXX IchXXXX
so I hadn't too many pcs on hand now. pls let me know anyone still had interest.
I still advise keep two pcs. Ver.3 ultimate ver. can use one or two chips, ( single or parallel operate). This year ned will supply full balance 1541a also use two chips. So keep two chips of 1541AS2 will be the best investment of the 1541a DAC.
thx
thomas
Hello Thomas,
I take you one TDA1541AS2 to put into the parcel please.
Here was my previous order :
- DAC v3 kit full assembled with CS8414 :125$
- 14 MKP matched caps : 5,50$
- CD controler Kit : 25$
- EMS: 13.5$
+ Paypal fee : 1.5% = 2.67
Total : 172$ paid (PayPal transaction 2WV05450UJ9459710)
So I'll pay 80$ through PayPal for this 1541AS2 as soon as you give me confirmation it's ok for you.
Thank you,
Nico
I received the fully assembled version two days ago. Took some time today to get it to work. Finally figured out the transformer wiring for 110v AC, soldered in some cheep rca patch cords changed a jumper to input rca and changed sw2 to 1 and 2 down 3 and 4 up and I got music. What I don't know is where all the upgrade caps go and how to tie the dac and cd rom contoller together.
tube-lover said:
hi kip,
pls read the message message 896 or directly contact RTD, he also in your country. the retrun email also send to your mail baox already.
pls let me know If still not clear.
thx
thomas
Hi kip and thomas,
the photo on post 896 is explicit on power trans wiring when using 220V/50Hz. In 110/60Hz you should probably wire the primary in Paralell (to confirm how).
There is a little mistake, I live in France and Kip apparently in United States 🙂. So wiring is different due to 220V in Europe and 110 V in US.
By the Way Thomas , have U send the CD Control Kit and Opamp ? I hope you haven't sent it to US 😀
