Newbee build: PA03 amp (LM4780)
For me, it's not always chasing the next best thing, but having a project to work on. The PA03 convinced me that I needed to build new speakers. Next is going to be a preamp of some sort.
After that I'm thinking either a DAC upgrade or a class D amp.
resistor configuration
ok people i'm baffled i have one board populated tested not working, my fault for bad solder on lm4780 chip. While soldering i accidentally soldered pins 26,24,and 22 together .Wanted to start on a new board, but then i noticed, in pics from other completed pcb's everyone's resistors are orientated different from then one on the site sjostrom's .i thought the resistors went on the pcb the way its silk screened .yet everone's pcb's are working but mine lmao,again my fault. Any help would be greatly appreciated regarding correct orientation🙄
@kallel123
If a board is finished it's imperative that you check the board thoroughly for correct soldering and correct placement of components. Orientation of resistors is of no consequence (of course values have to be correct). Use a magnifying glass. Carefully read the documentation. Look at posted pictures from other builders. First time start with variac or dim bulb tester. Then check rail voltages and voltages on testpoints TP1 and TP2.
This little amp is amazing and worth your time and money.
As peranders mentioned a set of (hi-res) pictures would be useful.
