New Reference Speakers with Full/Wide-Range Driver
DrewP said:
The old 108, although rising a bit when on axis would give as near to dammit a flat response out to above 15k just by going a tad off axis. Instead of sitting at the apex of the triangle with them pointing straight at you, point them just a fraction more towards straight down the room. You'll lose a tiny bit of the direct high treble at the top end but as it will get into the overall reverbant soundfield i doubt it'll be that noticeable.
Martin King shows a very similar phenomena with his Lowther DX2/DX3/DX4. Go look under projects on his site for some measurement graphs. http://www.quarter-wave.com/. A teaser below.
dave
Thank you Drew for the very informative run down for the Fostex Sigma series, you sold me to the 108. I might be testing these by Christmas.
The thing is that I want to replace a very shabby "FR" from RS that has a lot of shortcomings which I use without XO, thow I have been trying to add a notch filter for the 2.5Khz peak, but still remains another peak at 7.5K. Its a very lousy speaker to say the least.
What's going on with those funny looking ridged cones from Fostex?
Hey guys, here is the response I got from the Bert person that Dave mentioned. I have no connection with him, but thought that this might be useful.
Hi Mark,
> What would the cost be (euros is fine) for a pair of 215 RTF Supravox
(single cone) shipped to the USA?
These are 162 Euro each, shipping them to the USA is 49 Euro making the
total for one pair 373 Euro.
> How is the quality on these particular models. I know some Supravox have
had some problems. Are these OK?
I had one problem in the beginning (bad soldered contacts) but that seems to
be okay now.
Ciao,
Bert
BD-Design - info@bd-design.nl
Phone/Fax : +31 341 254500 Mobile: +31 6 51242990
Our Products, only the best! - http://www.bd-design.nl/main.php
____________________________________________________
As far as I can see the only downsides to the 108 is a limited bottom end extension a lower sensitivity and a lower power handling. All this adds up to LESS BASS.
Now me, I got funny tastes. I'd prefer fast/tight bass even if there's much less of it. So horn loading a 108 would be fine for me. I also have a loungeroom that's 12ft x 18ft with 8ft ceilings so i don't need mega volume.
You may find the 108's run out of "Ooof" pretty fast. I think BD design used them in a TQWT with 2 in parallel.
Re the "funny ridges" this is a new devolpment in the fostex lineup. I think they break up any standing waves across the cone (or prevent them forming at all in the first place). All the 108 Sigma series have been updated to ESigma. All the whizzer cones are gone which is probably no bad thing. Not precisely sure what's happened with efficiency, power handling etc but reports seem to indicate that the new drivers will be better sorted for horns. Looks like it's trickle down technology from the ultra high end Sigma ES Japan Only units of last year.
Drew.
And being discontinued getting harder to find
Not exactly new. This was 1st shown in the Fostex NF1 in 1999, from there into the Japanese limited editions, and now into regular production. Probably the most significant part of this trickle down is the trick surround.
dave
Is this thread dead? Where are you Lynn? Variac, Planet10, DrewP...... all others?
Is the Fostex FX200 a contender?
On axis and dispersion looks good. No whizer cone. Enough low freq to cross at 100 Hz or maybe lower. Only 1 mm Xmax but I guess it's OK for an 8" speaker. Only drawback will be eff quoted at 92dB. Anyone heard these?
Is it a Fostex? No bannana pulp cone, what a disappointment.
I see that most on this thread are playing around with 6" FR Fostex's so I had a look at models in this size shown at Madisound, I counted 7 of them.
Strangely enough the most expensive one, the FE168E Sigma, had the worst on axis response and the least expensive one, the FE164, had the best plot.
Have someone heard the FE164?
Those that have heard the FX200 like it... needs some help at the top.
Martin King used the FE164 in his ML-TQWT and is was good enuff for him to go out and get a set of FE208sigmas which has lead to a set of Lowther DX2/3/4s. He liked it. I don't think these are very available any more or at least not for long.
People that have the FE168sigmas are very enthusiastic about them. Hop over to the Full Range Forum and do a search on FE168.
My personal experience is limited to the budget FE103 sold as the Radio Shack 40-1197 and the alnico precursor that i have dubbed the FE103A. The RS is shockingly good, and they get better as you go up. I'd love to have the money to try a quad of FE108s or 168s.
What i'd really like to see is the new banana pulp FE108 with a smaller, more powerful alnico motor.
Almost any of these are the basis of an eventual 3-way, mostly full-range speaker system -- and it can be grown 1 way at a time. The choices and compromises you can make are legion and you can enjoy the music the whole way.
dave
Reality check?
surf said:
So by covering the 90Hz though 4,000Hz with one driver we completely eliminate all crossovers in the critical hearing, vocal and fundamental range of most instruments.
Is it really true that fullrange drivers do not introduce phase (or other) distortions similar to that of a crossover? Is a full range driver really better than a properly implemented crossover? Not questioning anyone's wisdom here, just having my moments of doubt. Here are some quotes from the fullrange driver website:
Lowther drivers, for example, radiate the high and mid frequencies from the cone, but the bass come out of a horn and are delayed in time and 180 degrees out of phase, as well as coming from the horn mouth rather than from the cone. So in a way, you have two frequency sources, with a crossover between them. The crossover is acoustic and needs to be tuned properly, and at the crossover frequency there is still potential for interaction of the two wave fronts.
Any attempt to explain full range cone-and-coil loudspeakers must begin with the fact that there is no such thing. Rather, such drivers are systems of two or more drivers on the same motor assembly. This may seem to be splitting hairs, but it is a very important concept in understanding drivers designed to operate full range.
The two basic formats for full range drivers are whizzer cone and center cap type. In either case, there is going to be a substantial peak in the frequency response where the main cone and secondary device are both active. This spike is most easily understood in the case of the central dome type driver, such as the JBL LE8T-H. If a measurement is taken of the physical width of the dome, and that measurement is then converted to a wavelength, it may be seen that the co-resonance of the main cone and the dome is 6.1k Hz. A measurement microphone will confirm this. This spike is fairly narrow in Q, but about +7 dB in height. A secondary resonance is created at the half wave point as well, or where the dome equals one half of 3.05 kHz. This resonance is lower in amplitude, and can be heard as "glare". In the case of the whizzer, or free cone driver, the exact point of resonance is more difficult to find with a ruler, but is still just as prevalent.
A free cone has many additional problems for the designer to overcome when compared to a center cap type. Free cones have radiating surfaces which are not in phase with each other, nor do the inner and outer surfaces receive the same air loading ( I've measured free cones which have 90 degree phase shift). The inside of the free cone is its own conical horn, while the outside is horn loaded by the main cone, which is an entirely different horn formulation. Anomalies also result from the outer edge of the free cone as the front and rear waves collide along this diffractive edge.
A properly implemented full range driver should be able to reduce these problems. But then, a properly implemented 'electrical' crossover (whether passive or active) should be able to do the same!
Regarding "Reality check?"
A widerange driver that extends from 80-4khz (nominally flat response within this range) usually means that phase distortion is kept out of the "critical region".
Normally the amplitude and phase responses of a loudspeaker driver are interrelated so that the phase distortion is essentially determined by the amplitude response. By "normally" I mean that the driver has effectively a "single location in acoustic space" (may not be entirely true for some driver designs, but mostly true for most drivers). If a driver falls off at the low end at 80hz with a 12 dB per octave rolloff, then the driver itself is introducing the same phase distortion as a 2nd order crossover at 80hz would. If the amplitude response is flat from 80-4000hz, and crossovers are applied at these frequencies in a manner that accounts for driver falloff and phase response, then the phase distortions are determined by these crossover designs and by the amplitude/phase responses of the lowest and highest frequency drivers at the lower and upper frequency extremes.
In simple terms, we are "mostly OK with our assumptions", but there are exceptions, and there are approximations involved. Certainly driver phase response must be considered as part of crossover design, and many useful crossover desaigns exist that are far from "ideal textbook" but still sound OK.
Hope this helps.
Re: Regarding "Reality check?"
This is what concerns me:
Variac said:
And I don't think we are pursuing a horn type speaker enclosure so that shouldn't be a factor
Agreed.
to jag:
Yes, full range drivers are usually not perfect, and usually have response amplitude and phase anomalies. If so, they must be tollerated, corrected, or discarded.
In my previous post I was making an extremely limited statement regarding phase distortion. If the driver has a frequency response anomaly in the intended passband, then for critical designs the response anomalies are "smoothed out" by appropriate equalization using active or passive elements (notches, etc.). If this can be done effectively (to obtain flat response) then the phase distortion is also reduced.
HOWEVER, some response anomalies are not so easily treated, and so some driver/enclosure combinations are a "lost cause". In this case the phase distortion will still be present, but such distortion is typically obscured by the more grotesque audible effects of the non-flat amplitude response. The more difficult to treat response anomalies include uncontrolled cone breakup and diffraction and/or resonance effects that can arise in enclosure/baffle designs that are dramatically poorly designed.
So, for example, a designer who wants to use a driver with significant cone breakup or other resonance will want to place the crossover well away from the breakup point, and possibly place a notch where the peak occurs. This sometimes works.
A designer who wants to avoid crossover distortions within the 80-4khz region (or wherever) will choose a driver that is flat or can be equalized to flat within that range.
goudey,
Thanks for your patience in explaining this.
Probably it was tacitly understood by others on this thread (that a full/wide range driver has more problems and you need to be extra careful in dealing with one), but I was getting an impression that using (any) wide range driver automatically resolves the crossover problems in the critical range.
I guess there are compromises involved in any design. And ultimately it boils down to personal preference as to what (compromise) sounds better to you, and which problems would you rather resolve.
Having said that, I am not implying that I am giving up on a full range driver - maybe it will also sound better to me (I have not listened critically to a wide range design yet). But, it is good to know all the issues involved.
wideband driver attributes
to jag:
"...a full/wide range driver has more problems and you need to be extra careful in dealing with one..."
Actually, the problems I mentioned are not particularly worse with drivers intended to be operated as very wideband devices. In fact, most "wideband drivers" that have succeeded in attracting the "single driver" crowd are typically far better with regards to cone breakup behavior and other resonance effects than are typical midbass drivers. Its just that when you allow use of a crossover you can "chop off" a problem area in the drivers response, while if you don't allow a crossover, then you need to be more concerned about the typical cone breakup region.
Most people don't place any priority on avoiding crossovers in the 80-4khz region (or wherever) until they hear such a design. But note that we end up with forums that specialize in such designs, and people who search out the ultimate wideband driver. So maybe there is "something to it". I observe that some prefer the wideband approach once they experience it, while others who are exposed to it are not particularly attracted to it.
How to read phase distortion?
goudey said:
From a technical standpoint it would seem from the above observations that some people are extremely sensitive to relative time shifts in "sine waves" in the 1khz-3kz region. A performance metric of interest would be the second derivative of the phase distortion within this region ("curvature" in the phase response). A crossover at 200 hz, for example, still has significant "phase distortion curvature" at 1khz. As the crossover frequency rises above 3khz the "phase distortion curvature" in the critical region diminishes quickly. This is all theory, but consistent with my observations.
Here are some measurements (by NRC) for a 2 way design. This figure shows on-axis, 15 degrees off-axis, and 30 degrees off-axis response. Note the dip at 1500 corresponding to the crossover at 1500.
Post contd. to next thread
Contd. from previous thread
Here is the phase response for the same design. Now, I actually see a lot of phase anomalies because of the woofer driver as opposed to the crossover. Or am I reading this right?
I apologize if I am taking this thread offtopic. Pl let me know if I should make this a new thread.
regarding amplitude/phase plots from jag
The amplitude and phase plots are not consistent with one another according to any physical model I am aware of for normal analog circuits. For example, the phase deviation where the woofer falls off stays within +/- 45 degrees, when I would expect phase changes to exceed +/- 90 degrees. In the phase plot there is no sign of the crossover, but phase perfect crossovers do exist. Such crossovers trade the phase distortion problem for problems with total power versus frequency. This type of cure may be worse than the disease. Some will not agree, but constant power versus frequency for multi-way system is a common design objective (all part of the trade space). I find it strange that the phase plot is nice and smooth and the amplitude plot looks like a typical measurement. Are you sure this is not the phase of the impedance of the design, not the phase of the acoustic response?
