GET HELP GETTING THOSE THINGS UPSTAIRS!
If i could i would. But it is also a measure of how my rehab is going. 2 years ago lifting 10kg was verboten, i managed near 30kg just a couls weeks ago, but used a dolly for most of the trip.
FH3 don’t weigh that much (<15kg) and have better hand holds. I’ll know before i get to the stiars whether i should continue.
dave
Yeah, maybe don't try this by yourself. I can come up a bit later and give you a hand.
jeff
Well that would be nice, especially if a pie that often accompanies you comes along — for the 1st time in my life (except whie in hospital) — i am trying to gain wait. And yours, and your wife’s, baking is sooo good :^)
dave
Pensil, FHXL, Scott’s ML-TL (which we built and is good), CGR dMar-Ken (the rectangular & trapezoid Mar-Kens could be kinda squat looking, but they will come (probably when someone pokes me willing to do a protype pair). Probably a couple other Scott designs i have yet to draw.
A basic 9-10 litre reflex should work too. There is no reason the A11ms could not be put on the side of a Pensil.
dave
Since the Alpair 11ms seems to work in an altered 9 litre Pluvia 11 box, will the the Alpair 7ms work best in a larger 13 litre CGR box ? If so, does a cabinet exist or can another CGR box for another driver be altered to be optimized for the Alpair 7ms ?
Inital modeling says 13 litres. I have some boxes already done at that volume, would just need to be detailed.
dave
dave
Has there been an updated drawing of the Pensil for the P7HD, I only have Scott's imperial one in my collection?
Can you email me that sketch, i seem to hav emissed it. Won’t take long to do a proper drawing.
dave
dave
hey guys
For the Frugel-Horn XL build struggling to find wool felt for lining the interior in india. Can i replace wool felt for any other widely available material..?
I am now trying for the first time a blend or composite material. It is synthetic blended with real wool felt (or so advertised). It is really just a pad for placing under an area floor rug. Look online for such a thing. Make sure they list it as a blend or composite; not 100% synthetic "felt". They come in many sizes, shapes and thicknesses. I have the thickest I could find easily sourced. It is about 0.45 inch (11.4 mm) thick.
berlyassocial,
You can try to locate jute carpet underlay / jute felt. I use that most of the times.
^ IDK about availability where you're located, but I've been purchasing UltraTouch R-6.7 Denim Insulation Roll 1.8 in. x 16 in. x 48 in.
https://www.homedepot.com/p/UltraTo...tion-Roll-16-in-x-48-in-60301-16482/202709974
Note, it's on the thick side at 1.8"
After doing mich search found http://www.madrasfelt.com/ has what im looking for and they can ship it as well
When searching look for what is described as industrial felt.
In my case; I am satisfied with what I am using; it is NOT 100% real felt. But; it is also NOT 100% synthetic either. The damping properties are quite good; it is easily sourced and WAY cheaper than 100% wool felt...FWIW...
- Full Range
- New Markaudio Drivers
