Master DAC (Boss) for RPI
Everyone knows there are many master DACs/ RPI on the market. For one reason or other , we were thinking that hardware implementation was not right so we decided to design one ourselves. We want to achieve the best quality possible for a reasonable price.
PCM5122 IC
3 separate LPF..one for analog , one for digital and last for oscillators.
4 LDOs , including a lt3042 in the analog section
NDK oscilators (44/48Mhz)
Film capacitors in the analog stage .
Supercapacitor in the analog stage
Extra copper on the PCB for low impedance.
Samples received we are assembling and testing.
PCM5122 IC
We are aware of this and we are working to address this issue on the next Kali.
Is there a timetable for the release of the next KALI board? Can you you let us know the differences between the current K board and the upcoming one?
It is known by many that the PCM series of recently are less good than their ESS and AKM counterparts. Why choose for PCM parts then ? I think this was mentioned by others as well.
The BOSS is meant to be a good audio solution for an excellent price.
PCM IC fits this and we have a few good implementations for it. This is not meant to be hi end solution , rather a solid entry point in the RPI audio. With and SBC + Boss you will have an excellent streamer for (less) than 100$.
We will announce the hiend solution once we are more advanced.
They are 2 different solutions. If you opt for Kali + DAC you could always use it on a different (slave) DAC
I am yet to hear the BOSS...will update everyone once I do.
Yeap , like usually we will announce the testing giveaway ..
Would you recommend this DAC over the Piano 2.1+Kali?
Any interest in giving out test boards?
Differences :
Smaller board hat size.
Firmware upgradable
3.3 v pass through
I would estimate 8-10 weeks to release.
Firmware upgradable
3.3 v pass through
Differences :
Firmware upgradable
3.3 v pass through
Thank you...
When I buy a Kali now, will it be compatible with this board? Or should I wait for a new Kali with 3,3v pass through and other fixes?
I want to connect a raspberry to my dddac with a clean i2s signal.
I am rather ignorant for the basis for using this third board, would someone kindly tell me what was the reason for it? The digi+ hat has oscillators on it and makes the Pi run in 'slave' mode to reduce jitter. What does this Kali do?
Would it work with the pi2design High-Performance Digital Audio HAT as well?
Coming Soon - Pi2 Design
personnaly I am waiting for a way to adjust the cutoff (LP point and HP point) between 60-150H without any Single Board Computer (sparky, raspberry connector input...) nor distribution , thinking using i2s input : either ask for a specially requested factory preset frequency or use purepath studio are the only feasible solutions ?
You need i2c thats how the TI chips works
What i would find even more practical would be to alter crossover freq and phase from the ui of my current audio player (be it moodeaudio or volumio or whatever). I find that finetuning per ear from your listening position works suprisingly well.
Rüdiger
Volumio already has that. (xover frequency from gui)..no phase tunning
Any further progress on this?
Yes our team is at full strenght and working on it. We expect a bug free release (volumio and max 2 play first) very soon but I wont commit to an exact schedule
Board has been tested. We got sound.
Regarding the quality...we honestly think this is the best implementation of the PCM5122 as a master.
Next we are building 50 units MP and we will have about 20 to give away for testing. However due to Chinese new year we will get the PCB in about 3 weeks. Once received we will announce the testers.
- Vendor's Bazaar
- New FIFO buffer for RPI/SBCs
