Hi cdsgames,
can I use 6,5VDC as well or will it destroy the Kali?
Rüdiger
Hi !
Have same question here.
My linear power supply climbs up to 5.6V and I'm worrying about frying it.
Is there a max admissible voltage ?
..or your BBB with external oscillator's I2S output is light years ahead of the RPi's I2S output..
And I guess the Kali/reclocking has evened out the I2S quality.
Hi !
5.5v max into the Kali.
See this exchange:
http://www.diyaudio.com/forums/digital-line-level/294940-new-fifo-buffer-rpi-sbcs-4.html#post4830934
Greg in Mississippi
We are using TI LDOs LP5907 LP5907 | Single Channel LDO | Linear Regulator (LDO) | Description & parametrics
SPDIF
...achievement, *unlocked*![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I give you one standard hifiberry digi+
* forced into hardware config mode
* set to slave mode in hardware
* kali MCLK pin29 --> digi+ MCLK pin36
All with jumpers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
sitting & working on the the kali (using the generic ES9023 driver)
( it did take an oscilloscope to slowly figure this out, the wm8804 datasheet & pin layout. What can I say, was bored this morning )
It's playing music!
Now to see if it's worthwhile (don't now if PLL still involved, all that crap) BTW, this is one of the buggy kali192's
(signals look crappy 'cause resolution goes down on the scope the more channels you use... can't get the full 1Gig samples/sec)
channel4 is spdif, then continues on to a Dac, listening now:
All with jumpers
It's playing music!
My kali....running on my akm board...
After 5 songs.... i have to say i m very impressed with sound quality!![]()
Are you taking the outputs directly from the Aout + pins on the chip, and through the MCaps? No other R/C filtering?
Yes... it works ok... cleaner than opamp...Are you taking the outputs directly from the Aout + pins on the chip, and through the MCaps? No other R/C filtering?
...more re: kali <--> digi+
verrrry sensitive to the MCLK jumper, just tap it all kinds of interesting distortion-- will need to change that. No wonder Ioan added a U.FL connector for that underneath.
notice the digi+ running without its always on green LED, maybe that's set on with the driver, interesting.
that orange GPIO LED is just set on by squeezelite, just something I do
Thanks Greg!
Didn't even expect to make that post, but it lit up & worked...!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Will follow up on sound quality. See if it's a go or not.
Kinda cool, huh... set a few pins low, jumper the clock over. So simplistic once you are there.
...been interested in this for awhile:
http://www.diyaudio.com/forums/digi...-new-fifo-buffer-rpi-sbcs-11.html#post4824748
SPDIF / KALI
Feels good to remove things
no need for that buzzing 27Mhz onboard crystal anymore:
https://youtu.be/zlqgAvFvsYs
Feels good to remove thingsno need for that buzzing 27Mhz onboard crystal anymore:
I'm guessing removing crystals means you like it?
BTW, love your choice of music... LOVE early Metheny!!!
Greg in Mississippi (who lived in Dallas for awhile and saw Metheny in concert while there!)
You cannot change/disable the bufferHi,
Is there a way to control reclocker buffer length by software ?
I'll like to have the possibility to disable FIFO latency for certain usage scenario (real time network audio) and to re-enable normal buffering for normal reclocked listening.
Is it doable ? Is the reclocker board addressable via I2C or SPI from SBC ?
Thank you,
@cdsgames
I second bismuth's request, it's impossible (without extra circuit / software hacks) to enjoy a movie or play a game with the latency present.
Also, AFAIK none of the existing reclockers have this functionality implemented, this could be your unique feature.
- Vendor's Bazaar
- New FIFO buffer for RPI/SBCs
