postalrat said:One more interested in a couple apeph boards and 4 or so power boards.
i challenge you to a minnesota aleph-off!
I ordered another 100 - Aleph amp boards a week or so ago, and they should arrive here within a week, and I will place them back up for sale on the website.
Brian
Brian
Mini Aleph Board set etc
Hi Brian,
I would also like to request 2 sets of boards as and when available.
John Caswell
Hi Brian,
John Caswell
Re: Mini Aleph Board set etc
They should be in by the end of the week, and I will put them back on the website 🙂
I still have about 60 power supply boards left.
John Caswell said:Hi Brian,
John Caswell
Joined 2002
mirfak said:Hi,
what is a power consumption of this mini-a? (trafo +/- 18VDC)?
W.
The mini A's use a 20V rail. I use a 300Va to run 2 channel's. No problems yet and been running about a year or more. I run 4 amps, 2 stereo blocks.
Joined 2002
Variac said:
If you run yours like mine 20V rails you will get about 18Watts 15V is a little low.
It all depends on your Heatsinks too, if you have small ones you wil want to run lower Rails, if you have decent sized ones, then run the 20V rails.
Jase
Aleph amplifier boards are back in stock, as I received the latest batch yesterday afternoon, and put them on the website this morning. I have a limited amount of PSU boards available, and will order more soon. I will take the PSU boards off the website for ordering when they are are out.
Brian
Brian
Joined 2002
Daveze said:Purchase made...
Woohoo.
Received it. After your order, I will only have a handful of PSU boards left. I will place an order for more in the next few days.
Ditto. Just for clarification, one set of stereo boards and one psu board is enough for one stereo Mini A?
dake13 said:Ditto. Just for clarification, one set of stereo boards and one psu board is enough for one stereo Mini A?
That is correct.
The MA-amp pcb set includes 2 - amplifier pcbs, and 4 - output boards (allow for 3 output devices each).
Just to clarify for the output boards, If you were to build a Mini-A, you would not use the output boards. For an Aleph30, you need 2 output boards per channel; Aleph60, you would need 4 output boards.
More details here:
http://www.diyamps.com/aleph/aleph.shtml
Brian
My apologies to everybody else that wants PSU boards too. I've been waiting a while for these to come along again and I just couldn't hold myself back..
- More Vendors...
- Chipamp
- new batch of mini Aleph amplifier and PSU boards
