new batch of mini Aleph amplifier and PSU boards
Hello all, I have an irritating question to ask...just got my Aleph boards from Brian and have most of the parts for the Aleph 5 - all transistors, resistors, caps, 1200VA 28-0-28 torrid, four monster 56,000uF caps, chassis with heat sinks capable of dissipating 150w per sink, etc.
Now for the dumb question - I know the components of the Aleph 30 differ from the Aleph 5, but can I build an Aleph 30 and put the +/-34VDC rails on her to get the equivalent of the Aleph 5 (provided the components are good to go for the 35V)?
I like the fact that the Aleph 30 has a higher input impedance than the Aleph 5 (my tube pre is a bit highish 3k), and I have the schematic for the true Aleph 5 too, just believe the Aleph 30 at the higher rails may be a better bet..
Thanks in advance
PierreG said:
Brian I need mini A amp PCB and 2 PS PCB. Will you have some Mini A amp PCB soon? It seems out of stock on your website. I want to make one order for everything.
mikeW sent me the gerber files for the mini-a PCB's .I've had some difficulty in uploading them to a fabricator as I've never done this before. Unfortunately Mike didnt know the answers to my questions either. If anyone is familiar with the gerber file process I would be most appreciative for the help.
Anyway I thought their might be enough interest to have some made .
Anyone interested can respond..
norazmi ... I use two of the heatsinks shown attached for my mini-A. It's more than adequate.
