NAP250 amp boards & regulator boards
I have posted a lot about that a long time ago - maybe I will find the images again.
You cannot see that clearly with many of the images found in the net, but a good proof is the fact that the two green wires run from the transformer to the centre ground between the main caps.
Payment sent thanks.
JeffYoung: 6 amp, 2 original_reg, 4 inverted_reg PAID
lohk: 2 amp, 2 inverted_reg PAID
john.luckins: 2 amp, 2 inverted_reg PAID
avtech23: 2 amp, 2 inverted_reg PAID
ultima legion: 2 amp (original_reg, inverted_reg, or both?)
jean michael: 4 amp, 4 inverted_reg
gary s: 2 amp, 2 inverted_reg PAID
Quantensprung: 4 amp, 2 original_reg, 2 inverted_reg
Skunark: 4 amp, 2 original_reg, 2 inverted_reg PAID
I did buy a NAP180 for the case (and NA001 transistors) so I can open it up and photograph it (assuming it's the same as the 250).
Jeff,
this is slightly off-topic but would you mind sharing a pic (ideally mounted) of the circular mil spec connectors you mentionned earlier in the thread ?
They are pricey, but I don't built 10 amp a year either... so this got me curious.
Max
PS: I found the datasheet/catalog page I have acces to pretty poor to be honest...
Jeff,
Max
Hi Max,
I will indeed. While the cost is eye-watering, they are really sweet.
(I should have a board built-up by next week. Ping me again if you'd rather see just a mock-up sooner.)
Note: 2 amp means 2 amp boards; i.e. enough for one stereo amplifier.
JeffYoung: 6 amp, 2 original_reg, 4 inverted_reg RECEIVED
gary s: 2 amp, 2 inverted_reg SHIPPED
Skunark: 8 amp, 4 original_reg, 4 inverted_reg PAID
--- waiting list ---
pem1: 2 amp (original_reg, inverted_reg, or both?)
Jeff
Quick mockup (in actual use I think I'd add some heatshrink at the end of the wire down to the shoulder):
attachment.php
Jeff.
Hi Jeff,
Those mil style gold connectors look the part. They seem to have a large contact surface area - are they quite tight when mated, i.e. do you need to give them a good tug to disconnect?
I would also add heat shrink down to the shoulder to "finish" them off - very professional looking.
lohk: 2 amp, 2 inverted_reg SHIPPED
john.luckins: 2 amp, 2 inverted_reg SHIPPED
avtech23: 2 amp, 2 inverted_reg SHIPPED
Skunark: 8 amp, 4 original_reg, 4 inverted_reg SHIPPED
Jeff
