Those wires looks same as live wire for buildings, good taste for audio in my opinion if they single solid core.
My feeling as well. I had one of those multi strand made for hifi cable before, and when I tried the single core copper live wire I had laying at home, the music opened up.
Saving money, and better music. A good combination!
Opens up. Exactly my experian also. But for some, opening up their signal chain is not a pleasure so there are also a lot of nej-sayers.
Pink noise. By my laptop 😉 still, I think it looks like 3db/oct? Baffle just leaned into the cabinet. Sound is not awful 🙂
Half wa assembled and already impressing. Eq bye ear more or less so see great possibility for improvement. Where will that end? Haven't even sealed the enclosures.....
Today some tweaking. The baffles are still only "leaned" into the cabinets so no bass but some resonance? Still very positive!! Measurements in listening position.
We are sinking. Some leakage causing loud shhhff etc. Both around a few drivers as well as the baffle which baffles me 🙂
Ha ha sounds you have great mood there even after reporting leakage and we are sinking, thanks for that : )
If you still have some of those plastic cups from baffle casting suggest fill some with bear and call a friend that is certified to remove those mains installation and repair the leakage and BTW have best fun and weekend.
the song of 144 metallic wings....
The driver has these wings for mounting and when as I have done, mounted from the front, the sit there and sing their high Q song. To be fixed. As well as the long gaps beside the baffles meeting the cabinet. This will probably elevate this to even higher stratosfärs 🙂
I hope you'll find a suitable solution. Most of the fun is just starting out, much more to come I'm sure...
Now you know why I have a gazillion bolts holding my baffle 🙂.
What is the seal between the baffle and the enclosure? Butyl rope is good stuff!
You'll find a way I'm sure. There's a lot of potential in these speakers!
Swinging my mic (m!) around my listening position gives this...//
Is that measurement just the arrays or is there a sub as well?
- Full Range
- My FR10HM corner-ceiling-floor-array
