My custom tube preamp - Full build advice
So after ordering some aluminum angle that’s 3.2mm thick, 45mm by 25mm.. Only after cutting to size I realized that it was far to large to use for my DIY heat sinks. Dough!
Now I have decided to use 15mm, 40mm and 1.5mm thick. Much more like it!
For the heat sink ‘fins’ I used 20mm, 20mm U profile.
After a lot of sawing, drilling, filing and finishing. I have these parts:
Here is how they look mounted on the power supply board:
Power supply testing went well, with extremely low ripple under load in the millivolts, both for high voltage and filament voltage.
I tuned the filament voltage to ramp up quick enough to prevent cathode stripping, but slow enough to reduce the inrush current to a sensible level from a cold filament.
Thinking of the next step the preamp itself. It uses a JFET input, bootstrapped tube VAS and MOSFET output. The amp is also non-inverting.
I fired up the soldering iron to get started on the preamp PCB:
Construction went well, and the tube socket (complete with slightly gimmicky orange LED underneath) seems to cope OK with the physical stress of inserting and removing tubes, although this was a slight concern.
I picked 2 of the closest matching resistors for R16 to help match L and R channels gain as they are only 10% tolerance resistors. As well as making a mount to keep the resistor cool:
Now I have two completed preamp boards:
Now for the testing..
B+ high voltage sat at about 260V
Distortion seems to reduce slightly at a higher bias (as predicted), so I settled on 155V that held very stable (+/- 1V) for about an hour of testing:
Now for a look at distortion, the load test is a 10k resistor.
Here is an FFT at 30V peak-to-peak:
Frequency response is a non-issue, it’s as flat as my sound cards outputs:
_________________________________________________________________
Overall I am very happy with these results, especially being my first valve project.
It hits all the goals I set out to hit, I have had an hours listening test and sounds pretty good to my ears, the noise floor seems extremely low, no buzz or hum (despite missing C1 that I will order later). I look forward to listening in stereo to assess the amp properly.
The heat sinks run cool, in the mid 30C range so should be fine in a vented case.
So the most important work is done, but its by no means over. I still have to construct a chassis and front panel control PCB for pots, switches input select relays and so on.
The chassis is planed to measure 400mm by 400mm and around 85mm tall. A big amp.
I'm thinking of using 2/3mm aluminum for the bottom floor and front and back, perforated sheet with 8mm hole size for the top, and nice wooden sides.
Here is a rough layout of how it may look:
I will also attach full final schematics for my build and hope it will be useful as its quite a unique design.
As for transformers I thinking of using the Triad Magnetics VPT series.
Triad Magnetics VPT18-2780: 9V / 18V - 50VA [https://www.mouser.co.uk/ProductDetail/Triad-Magnetics/VPT18-2780?qs=wkKrz7WmEgOsofzfskZP0w==]
Triad Magnetics VPT230-220: 115V / 230V - 50VA [https://www.mouser.co.uk/ProductDetail/Triad-Magnetics/VPT230-220?qs=wkKrz7WmEgMVJQHjyRuIng==]
I know the high voltage transformer will result in around 325V DC after rectification, that's 65V to high that will need to be dropped by the power supply's MOSFET.
I cant seem to find a more suitable lower voltage transformer on Mouser. Not ideal but as long as the 400V rated capacitors hold up, it should be OK.
