My class D amp
Hi All,
Success of my (smd ver.) AUD1000SD/1500SD , I start to design a small AUD500SD {size L=3" & H=2" vertically mounded} its for home theater purpose(those who are loved HT)
attached my design :)(not completed)
max. supply +/-65V
max. output 1000W@2R, 525W@4R 260W@8R load
MANOJ
Hi Mr. manoj,
I have a question about the inverter IC,
Is there any special purpose to use 3 inverters on serial mode before feed it to the
HIN of IC IRS2110 (Picture 1)?
What happen if we only use 1 inverter each before feed it to HIN and LIN of IC IRS2110 ( Picture 2) ?
Warm Reagards
Syaelend
I don't know if some one has ask about this before if its please forgive me.
I try to build class D based from IRS2092 but I can not find toroid T130-2 for LPF locally and I think to use ET49 from old TV PSU yes I have an LCR meter to wind the coil to value I need but I not sure about use gap or not gapping for this purposes. can some one shed a light to me in LPF must I use a gap or its must be gapless ?
thank You
Hai manoj sir ,
I droped your 250sf due to the presence of smd parts, cos am not gud at SMD & dont have soldering station for it. So once again am going to explain my need, sorry for that.
1. I need an Amplifier for SUBWOOFER. But right now am confused in selection of subwoofer. Do i need 4R or 8R subWoofer which is ment for Home. But am certain about the wattage & size ie, 250W 12". Please can you help me.
2. For this which Amplifier should i use.
- YEDU
Hi All
my new simple class D amp AUD200U
8R @ 125W , 4R @ 250W & 2.6R (3x8R) @ 380W True RMS
8R @ 250W , 4R @ 500W & 2.6R (3x8R) @ 775W Peak RMS
cost @ INR 950.00 only ( material+man power )
Size 10 x 6.4 cm only
With DC protect
Optional Temp Protect ( add INR 100.00)
Optional Signal Limiter ( add INR 100.00)
Optional OC Protect ( add INR 250.00{PCB size 12 x 8 cm})
MANOJ
