there is a result of 178 hits for a 0.1uF 25V 0805 ceramic capacitor on Mouser.. depending how you search. Strangely they don't seem to carry my favourite brand Susumu anymore...
GCM21BR71E104KA37L Murata Electronics | Mouser Deutschland
A radial capacitor (film) in 10uF 50V 2.5 pitch does not exist... only electrolytics.
Here's my USA mouser BOM for meldano's muses implementation. I based it off a BOM I found in the Muses thread, but I can't seem to find the post now to give credit to who originally put it up! I made some adjustments to the connectors—different pins that I like better, and 3 pos and 2 pos headers that don't lock/latch and allow for separating the main power from the display connection (I left the latching headers in the BOM). Per his original smart idea coding—"C" is for Controller board and "V" is for Volume board. 100R on controller R1 when using display, 1K on controller R1 when not using display. BOM is for SE, but I put in larger quantities than required for a lot of the parts. (Oh, and the through hole resistors aren't in the BOM....)
Member takitaj! Thanks for the OG BOM, and it was in this thread.
Thank you!
When looking at the controller PCB from the top, there are 2 jumper pads in the lower left-hand corner. I can't find any info in the documentation as to what this does. There is a J1 on the controller schematic labeled 'option'. I'm just not sure what option is implied. It's tied to pin 7 of the 10-pin SIL directly above it, used to interface with the volume board. Can someone enlighten me.
I understand J2 on the bottom side of the controller PCB, and the J1 of the volume PCB.
Since the shipping costs have reduced, I would go ahead with ordering.
Thx.
Thx.
Hello,
anyone from US want to share the shipping cost of ordering kit from from Daniel. I badly need a microcontroller since I misplaced it when I purchased the kit from him. If anyone is interested in sharing shipping cost please send me a pm.
Regards,
Subbu
I used the x3 connector on the controller PCB. However, I think they are wired in parallel so either should be usable. I did not test that yet. I’ll test in the morning.
Thank you!
i Daniel,
I completed my VC today. Please see post #1782 in https://www.diyaudio.com/forums/pass-labs/329240-waynes-ba-2018-linestage-179.html#post6364243
I am planning to install the isolator when the socket arrives and will report back. Thank you for sharing this to us!
Abe
Abe
