If you go to Las V today you may have to pay extra!😀
Who is the fat guy with you?
The blue one?
Thanks for that - I had totally forgotten about Goethe's "theory", but its more than 50 years since I last heard of that construct.🙄
I suspect that this is the passage from your link which may apply?
Goethe expresses this more succinctly:
Yellow (Golden?) is a light which has been dampened by darkness; Blue is a darkness weakened by light. 😀
No more OT nonsense - for now!😉
I have just been told that the blue one is in fact the golden one!
Actually the blue one is one of the ATL guys. He/she/it is using his 'PePu' (pronounced as Pee-Poo) otherwise known as a 'Personal Environmental Protection Unit'.
Hi All,
Best wishes for the new year, and if you was wondering what I did during the holidays 🙂 then here is a picture.
2 x (both sides) Mains 'ground-rail' guard (no solder mask)
1 x Mains DC-blocker
3 x Fuses for Transformers
1 x 12VA 9V Transformer + Rectifier + Capacitors
4 x 20Amp Bridges + Snubbers
6 x DDRC ( InR/InL, OutR/OutL, 12V and Case )
2 x N0X
All connection support for Mains(3x) Primaries(4x) Secondary(8x) Elco's(8x) and DDRC's/N0X's using headers(3x).
The boards will be 2.5mm thick with 4oz copper.
It is designed to set on top of 2 toroids (in my case 2x 600VA) The 4 blue circles (on the large circle) used for rubber standoffs and the big central hole used for mounting on the same screw that is used for mounting the toroids. The 3 holes (in the HV section) should be used to mount a Plexiglas 'roof' over the HV section for safety.
Tomorrow I will order 10 of these for myself, but if you would like to have (unlikely) a few then quickly drop me a PM.
complex psu... what are you using it for ?
Hi All,
2 x N0X
If you want to know, the next step 🙂
Hobby Electronics | Flickr - Photo Sharing!
Very good looking 🙂
These here seem interesting for audio :
NPN and PNP Monolithic Dual Transistors from Linear Integrated Systems, Inc.
70 is the new 50, dead is the new alive Frank Doris
Distortion cancellation --
Cancelled? Did I hear someone say CANCEL!
Thx-RNMarsh
It doesn't seem you guys realize this, but the Vbe nonlinearities in this EC topology cancel.
Instead of using two PNP's for the mirror, it is better to use an NPN and PNP, that way the complimentary parts' differences in matching are also cancelled.
Thx-RNMarsh
Cancallation of thd --
This is where its at. Cancellation techniques. Lets see more of these techniques instead of nfb etc to reduce distortion.
Thx-RNMarsh
It doesn't seem you guys realize this, but the Vbe nonlinearities in this EC topology cancel. It is essentially the Tringlotron, except input and output are able to share a common ground. I came up with this independently many months ago and have done several experiments with this topology since it is extremely fast and should allow improvement in linearity of various circuits by canceling Vbe distortion directly rather than hoping to attenuate it to a satisfying number of zeros. As it turns out, BC5xx/BC3x7-40 have close enough Vbe that they should be matched enough to do very well in this topology.
Instead of using two PNP's for the mirror, it is better to use an NPN and PNP, that way the complimentary parts' differences in matching are also cancelled. I have built this circuit several times and it works as expected. By trimming the match you can get a positive or negative 2nd harmonic. This gives very subtle acoustic effects. You can get very visceral bass this way.
I have tried NXP BC8xxC duals for this but surprisingly, they don't actually seem to achieve better thermal coupling then two TO92's. This frustrated me, besides the attempt to p-p solder the SMD package.
The speed of this configuration makes it useful as a very fast buffer, and so naturally it could find application in linear regulators, amplifier stages and so on. One problem is that input resistance is negative at at high frequencies, and output resistance may be negative, which is what the 4.7R is for.
So I regard this as an improvement on the Tringlotron.
The biasing scheme keeps the temp of the transistors roughly equal; coupling TO92 transistors really doesn't help much with the thermal differential.
Also attached are FFT plots with and without the buffer. I don't trust these results, because the 2nd harmonics did not respond to trimming at all. I think something else was causing the 2nd harmonic and the buffer's actual H2 was obscured by it. I seem to remember getting -90db with some other configuration. Still, we know that THD is at least that good.
Thx-RNMarsh
These are what we have been waiting for !! I'm ordering a boat load of them in case they stop producing them in the near future.
Frank Doris? Is he still rocken and rollen? Is he the new alive?
Thx-RNMarsh
67 is the new 47.
I believe that sometime over the summer he realized that the task was just too much for him, or he got other priorities... Last post was the 24th July.
What happened with Stefanoo Masterpiece phono preamp?
It went boldly where no balanced-preamp ever went ... 🙂
