MPP
I found it, post 42, that was a long time ago. I did also a balanced version of that one.
Post 42 has a little DC offset at the input that is the difference of the PNP and NPN Ube.
Could be solved by swapping the Ube transdiodes from one gender to the other.
The we have a PN NP drop on both polarities. Shunting the transdiodes with high value elcaps will lower the noise by 3dB.
Yes, the link shows post 42.
The small offset is no problem if you adjust for instance one of the input current sources.
Some improvements to this basic circuit are possible in order to arrive at what is my preferred topology.
I am curious how you derived this "Malcolm Hawksford Homage", I am not familiar with the abbreviation LFD.
It has an interesting gain structure : I-U, U-I, I-U. U-I
I don't agree with that, it is current in, current out and buffer.
