MPP
pls give me a day, tomorrow I have to take care of something else, so I can't go over the values, there's is a few places where we're on the limit with currents and derating. I have to look into that,
I run 2.5 mA through each input transistor 10 mA in total through the first mirror, this give the Jfet CCS a little heat problem as it need's to be set somewhat higher app 50% at 15 ma to let the shunt have some current to work with
Other limit area is the JFET CCS for the buffer....It sees high voltage and is run at 10 mA, so it's also loaded a little high, so the floating mirror CCS may not be susch a bad idea....
I'll not include any other networks than the RIAA, but I do think that Jumpers Will be a good idea
I also think that a double sided layout with a ground-plane would be good (That how they used to do RF layouts at my former job (Sailor VHF-radios)
GND plane can than be split between buffer and frontend.. and jumper connected
For me it would be : 50usec - 70usec that is easy, two different caps
2.2use ( Neumann pole, though this is neither a pole, nor always correct because many lathes roll of 2nd order over 50kHz and not first order, see "Cut and Trust" published in Stereophile ), easy too, just add a resistor in series to the lone 75usec
cap)
Then i have a collection of Decca, EMI, RCA and Mercury classical records. I have also Blue Note, Verve, Vanguard records. Mostly Jazz, some mono. Thats all i ever need.
I have a lot of older Deutsche Grammophon, Telefunken, Philipps etc where some may have the 50usec so this is already covered.
This is how it looks according to my information...
This is the "Other" curves when played through a RIAA filter.
Hi, thats exactly what I will do. plus a few more... :
symmetrical layout
power supply decoupling close to the high current paths
remote sensing for the shunt regulators
input / output separation
thermal considerations
my feeling is that people would want to build standalone phono preamps with this, so the attached layout sketch might make sense - please comment!
Not too sure about remote sensing, it may oscillate. Keep the regulator near the preamp and you will fine, at 105mA I do not think that remote sensing will do much good.
That is what I would do (did)
Flickr: Search F.d.W.'s photostream
well, that may lead to parasitic oscillations due to the large parasitic inductance of the cable - something to simulate (try a few microhenry....)
(I know a current source is supposed to behave like an inductor, but there is also parasitic capacitance here....)
