Moode Audio Player for Raspberry Pi
Tim,
I did one more test.
To eliminate possibility of broken sd card, I've moved my pHat DAC and wifi dongle from PiZero to Pi2b and used the same card.
Tadaa! System woke up and all works perfectly (network, mpd, library).
Looks like there might be some incompatibility of the newest version with PiZero and Pi1B.
Update to 3.0
Tim, let me start with saying 'thank you'. What's coming next are no dealbreakers, just things I ran into and could mostly fix myself 🙂
I updated to 3.0 and got the "mpd-config: connection to mpd failed" message after saving MPD settings, but reloading the page (and restarting mpd) seemed to fix the issue. So this was after the 'mpdcfg' job, and I could still do a 'mpdrestart'.
Music was playing fine after opening 'alsamixer' via ssh and setting volume of my external usb device to 100% (I had already set it to 100% in the interface and set volume control to hardware to no avail).
Tim,
Confirmed on Pi1B here..."mpd-config: connection to mpd failed" when trying to access MPD or Sources configuration pages. Also Audio Info page is blank.
Download verified and fresh install on reformatted class 10 card. (Using DD and Ubuntu)
Tried restarting MPD after ssh into Pi . MPD restarts but this doesn't have any affect on the webpages access.
The same image works fine on Pi3.
mpd-config: connection to mpd failed // CPUAFFINITY
Good evening Tim, all,
First time user here after several years of volumio and seriously disliking its v2.
I have a Pi B+ with an IQaudIO Pi-DAC+ and am getting the
"mpd-config: connection to mpd failed" error.
In syslog there is a pointer to the step where it fails:
Nov 28 18:15:05 moode systemd[1]: Starting Music Player Daemon...
Nov 28 18:15:05 moode systemd[1]: Started Music Player Daemon.
Nov 28 18:15:05 moode systemd[7088]: Failed at step CPUAFFINITY spawning /usr/local/bin/mpd: Invalid argument
Nov 28 18:15:05 moode systemd[1]: mpd.service: main process exited, code=exited, status=215/CPUAFFINITY
Nov 28 18:15:05 moode systemd[1]: Unit mpd.service entered failed state.
Any thoughts on how to fix / work around this?
Thanks for your consideration and for, what (still) looks like, a very appealing distro / audio player.
Just upgraded to 3.0 Seems to be working fine on my PI3 using onboard audio. Tweaked the config.txt with "disable_audio_dither=1 and audio_pwm_mode=2". Nasty audio hiss now pretty much gone.
I was wondering if there is an addon available or even a command line method to perform an Equalizer function to tailor the headphone jack sound output to users preferences (jazz, setting, rock setting, etc..). Can this be done if using a DAC (IQAudio)?
Thanks and keep up the good work. This player is excellent.
Thanks for the syslog output. Try the following:
1) sudo nano /lib/systemd/system/mpd.service
change
CPUAffinity=3
to
#CPUAffinity=3
2) sudo systemctl daemon-reload
-Tim
I am using the Pi 3b connected to my tube Dac which uses the XMOS X20 chip. Getting this to work is hard,, a real bear yet when it does, the SQ is great. I shutdown the PI after I am done listening so I shut of the hard drive. Today , when I booted up the PI, the MPD dis not see the USB so i hard are hard time getting it to work yet after 10-15 minutes, it did work and the sound quality is excellent. I usually use the Hifiberry Dac + Pro Dac yet mine stop working. I have one on order so i am using my tube dac. Tim,. is is possible for you to add the XMOS X20 to the devices list?
