Midrange experiment with Auto sound panel deadener and high density acoustic felt..
That's funny! An incorrect semantics assumption on my part🙂, but I can see cotton bath towels working excellent too.
Probably the best thing(For my needs) would be to use high density industrial wool felt, which is VERY expensive and very heavy. It would probably cost at least a couple hundred dollars to fill both cabinets. Ain't gonna happen! The dryer balls are much cheaper and I don't have to cut anything, I just have to wedge them in. They'll cost around $50.00 for both cabinets, and that's filled to the brim.
F-1 Industrial Felt By Foot
– thefeltstore.com
This is the absorption response, 10cm thick of the current, high density felt I'm using, with no added airspace between the mic and the driver, vs nothing.
As you can see, it's either resonating at certain frequencies, or it's completely transparent at certain frequencies. Either way, it's totally unacceptable. The null at 300hz, and another at 150hz makes me think it's a resonance problem
F-11 or F-13 felt may be a better and less expensive choice for noise damping.
SAE Chart - Sutherland Felt Company
You're absolutely right, those would be, but the cutting part to fill a cabinet completely really sucks and I don't want to go through that again. These 100% wool dryer balls seem to have the perfect amount of density and size for what I'm trying to atchieve, and they'll conform to the corners and walls when wedged in together. I'll see how it goes. Should be interesting. I'll take some pictures too.
My scientific curiosity finally got the best of me. I put so much work into this that I had to see exactly what was going on inside the cabinet, so I drilled a hole in the bottom(mic barrel diameter) and stuck the mic in. The news is very good! No resonances at all, with a smooth downward trend through the midrange. Exactly what I was hoping! Driver amplitude remained the same for both measurements.
It's actually kind of cool to have mic access to the inside of the cabinet. Since it was drilled on the bottom, there's no cosmetic sacrifice.
There was a small amount of air leakage from the hole(tiny port, which could effect the low end of the measurement), so the next measurement will be with the mic sealed in.
Orange - Direct driver response
Green - Response from inside the cabinet
Driver on axis vs mic sealed into cabinet. Much lower bass. I was wrong about this product. It really does work, at least when it comes to what it does inside of the cabinet.
The response I'm getting does corespond very well to their published coifficiency curve. It is a little off because of how I'm using it.
Here's an interesting measurement. Internal(Sealed in mic) Fundamental, HD and noise floor..
Also at the same amplitude, but outside, on axis..
Correction- There is no such thing as "coefficiency", only "coefficient", and the plural.
Scottjoplin
I did some calculations, and sure enough, internally there is..
a peak at 2.1 khz corresponding exactly to the internal width.
a peak at 1.2khz corresponding to exactly the internal height.
It also looks like below 800hz(Below the wavelengths of the internal dimensions) the internal cabinet pressure starts increasing more and more.
