Masterpiece
there's is also a Pspice model, that can be used in LT-spice, but as a sub-circuit, It's beyond my skills to build a working model from that. LTspice has a lot of op-amps built in also differential ones and sub-circuit ones, but finding the right "similar" one can be a hassle.
That opamp can push more then 100mA so why the need of a buffer ?
Can you show me the creators response ?
Juma did that opamp ? Unlikely.
This is new to me.
I have under certain circumstances experienced that this chip can get quite hot, that can be solved with a copper trace in the MOPS version and with a cooling profile in the regualr SMD version.
Yeah kind of arc to convert from PSpice to LTSpice.
I will have to find a suitable part to create a model for the circuit.
... I will try those.
Ricarditto,
easier to find if you google punch Philips 60pF.
e.g. : Teflon trimmer 60PF van Philps -hf-electronics
or 2222-809 (-05xxx to -09xxx ,are the ptfe series of Philips/BC components)
e.g. : https://www.elfa.se/elfa3~tr_en/elfa/init.do?item=68-798-03
Or http://www.newark.com/vishay-bc-components/bfc280908002/capacitor-trimmer-4pf-38pf-300v/dp/98K7134
Same routine at ebay.
Or be a teflon cheapo : adjust a polyester trimmer cap to value, then exchange for http://www.diyaudio.com/forums/pass-labs/156397-pearl-two-8.html#post2251685
(as a part fetishist, my religious beliefs forbid such activities)
Ricarditto,
Or BFC280908002 - VISHAY BC COMPONENTS - CAPACITOR TRIMMER 4PF-38PF, 300V | Newark
Or be a teflon cheapo : adjust a polyster trimmer cap to value, then exchange for http://www.diyaudio.com/forums/pass-labs/156397-pearl-two-8.html#post2251685
Just one NOS trimmer available ...
Joachin,
I have creted a schematic with the differential input stage you had proposed on Paradise thread and used folded cascode to have a fully DC coupled differential in/out.
I thought this would have been worth posting it here on the Masterpiece.
It simulates great and everything.
The only problem I was unable to solve so far is the servo for differential.
I have been thinking and playing around but I cannot come out with something that works symmetrically.
I hope someone here will have some idea.
Joachin,
You can not make a single servo for a balanced circuit, you need to use 2 servos. R12 must be split for this.
OK, so this is more or less a Paradise with the new input stage.
Yes, i know. making a servo for this is a major challenge.
I did not find the time to look deeper into it.
it is more less a differential input with mirrrors 😉 anyway....yes servo there is a challenge.
Don't you however think that this could reserve some good surprise over the OPA's approach or you still think the other way will yeald to a better result?
If we could design a servo here I could try it and see how it sounds and then report!
How would you split it? to in series with two servos one at each end?
Could youy show me the priciple?
I am aware that I need two servos in the schematic I have included just one but I was playing with the differential one as well.
