Mark Levinson No23 repair help
Now I found the right function from the scope. It is precisely 156mV, Need to measure again from the right channel.
Yes, I have been thinking about that. Quite expensive though.
One guy from the forum contacted me about old non functional ML23 main boards. They might be good boards to get spare components.
Should I test also the capacitors in the VCC prereg line(C301, C302, C305, C306)?
Same lamps, same formula?
You didn't measure Vripple of the left amp with lamps in the V unregs did you, because that was not the idea. R20 should be 27.5mV while measuring Vripple.
That makes the total current drawn from Vcc unreg I=0.32
Measuring the other 4 caps is best done by first inserting an amp meter in the resp Vcc Pre Reg lines and making notes of the current in amps drawn.
Then when knowing this current I, you can again calculate C=I*0.01/Vripple
Hans
Oh, I see. Then I had the lamp between the VCCs. Now I measured without the lamp 125mV ripple(R20 = 27.5mV), which makes 25600uF.
It is a big differenece between the channels. I will do the same measurement to the right channel when it works again.
I have solved the 15mV output voltage.
Q9 has 1mA collector current, hfe is ca. 300, so Ib is ca. 3,3uA.
For DC, the minus input sees R121 and the plus input R76.
Since R76 is 4k7 smaller, Ib going into Q9 causes ca. 3.3uA*4k7 = 15mV offset voltage.
Hans
