Marantz MA9S2 choke input power supply
Those marked points (J504, J505) in the 3D photo are just the vias connecting the upper and lower layers.
In the photo below you can see that there is a wire soldered to J504, this probably goes somewhere on the chassis.
There is no J506 in that location. It is actually J505. J505 connects J501 and to J503. J503 is then grounded through the PCB mounting hole screw. J505 also has a wire soldered in it that goes down to the chassis bottom plate and connects to ground there.
It is like this on the PCB:
Reactions: 1 user
Thanks a million for the help and the pictures Mark ! This amplifier is a pure art.We are clonning it.We hope we can work it well.Maybe i can make it only one pair of output because of i do not need such high wattage but want to experience this amplifiers quality.
Maybe better to make it as Marantz intended, sell it to a rich audiophile, then use the earnings to help pay for yours :)
Otherwise, it wasn't really designed to run with one end of the speaker tied to ground. You might have to tweak the circuit a little for that to work optimally.
Reactions: 1 user
