8Riccardo9 have you built the SMPS that you gave the pcb for?
Does it work ok?
Anyone else has built it?
I don't have access to an oscilloscope (as suggested at Rod Elliot's site) and I'm hesitating in building it. Has anyone built it, successfuly, without testing it in an oscilloscope?
Does it work ok?
8Riccardo9 said:and this is the power smps that i have built last time
this is the final versione
the design are in the eagle format
bye
Where is input and output inductor?
the input inductor will be put out of pcb, in the box of the amplifier and connect to positive of battery and positive of circuit.
there aren't output inductor, if you want him you can put.
simingx said:I have built the PSU and it works!
Slight modifications (to make the circuit similar to the one found at ESP):
10k resistors replaced by 12k
Remove one of the 10k resistors immediately above the 3525
Remove the 1k resistor in the same place
Add a 12k resistor from pin 1 to pin 9 of the 3525
Gate resistors changed to 22 ohms
MOSFETs used are Infineon SPP80N06's and output rectifiers are MUR1520s.
The shutdown/standby circuit works, it disconnects power to the chip instead of using the chip's own shutdown input.
Efficiency is >90% (estimated), the (small!) heatsink only gets slightly warm at ~100W output.
I accidentally shorted the output while testing... nothing happened other than a BIG spark.
This will power a pair of Red Rocks Audio D200's 🙂
Hi simingx
I am trying to replicate the smps project on ESP page
i like your design and would like to copy it
on the ESP page: http://sound.westhost.com/project89.htm
you have two shematics, the original one at the top of page and the simplified version : my question which one did you modify ?
on the image you posted , i see two transistors? are these to drive the Mosfet's ? if so they should be 4 , 2 to make a push pull
what's that small choke beside the toroid?
are you using a single input capacitor?
could you please post the final schematic and the components ratings, i 'll be thankfull
by the way guys this a great thread , please keep feeding it with your awesome works
dear sir i want 12 volt dc input 24.0.24 ac out put cirguit please sent my email id vmsmmy@yahoo.com
Is this possible?
Is is it possible to make project like this but with only one output rail (e.g. 50V), same low voltage side, just to make one winding on secondary of transformer and than all same (full bridge rectifier, inductor and capacitor)? 😕
I tried to do this
, but i have some problems
, so i need second opinion can this idea be realized?
I tried to do this
yes, but you still would have 2 secondarys, full bridge rectifying, feeding one output indictor, capacitor(s)
Center tap would be GND, other ends would be + going to diods, inductor,...
OK, thanks, but....
I found one previous post by Eva:
In a push-pull converter symmetric output rectification is required for proper core flux balancing. Use either two windings in opposite directions and two diodes or a single winding with four diodes.
I know what you mean, luka, but i think that eva's post is true, and i tried something already, and i have some results, except i have a little problem about voltage drop on output.
I one question, how to determine primary number of turns for different cores and input voltage? I know there is a lot of books, but as i sad i'm little 😕 so i need some quick guide to determine it.
Thanks luka, first class site is impressive. 😱
hi,
sorry im a fresher,
my i know how can i connect from the amp pcb to power supply pcb?
also where is the input connection of rca and spk output?😕
sorry im a fresher,
Yea nice im interesting in ur amp,
pls send me the pcb layout n schematics for me niccm0314@hotmail.com
thank u...
thank u...
all I can say it works, a lot of heat, maybe its just me, I don't like that... other than that, works great
Link to DIY Car Amplifier
Hi
The project car amplifier KAC 716 is published in two magazines. Info ELEKTRONIKA - Casopis za elektroniku and ЕМИТЕР - Списание за наука и техника.
PCB can be found on: Info ELEKTRONIKA - Audio Projekti 14
The full article is on elektronika.com.mk but on Macedonian language.😱
Regards,
Hi
Regards,
- General Interest
- Car Audio
- Making car amplifier SMPS with tl494 + DC Protection
