Yes, Vunce. 70mH, 5Adc and max 0,7 Ohm Rdc with frame. Maybe for 30 pairs the same price.
what iron laminate ? ie we can have a better one with small charge ? to US will be cost more the shipping...
Great Peppe! Maybe they can make it even lower price without frame?
I am in for at least 2 pairs
Do they have any picture and the specs of core material?
...we can start a GB
Just to register my interest.
Maybe mention this on the MoFo thread (and perhaps one or two others)?
Ok, I begin by maing a post on MoFo ThreadYes, and start a new GB in the GB forum if it’s ‘cross platform’ compatible for MoFo and LuFo, and other amps. I have seen several choke loaded SIT threads.
[EDIT] Done. Link to MoFo discussion
Is there a simulated data about Zout because cascode will increse this value.
The predicted DF was 156 at 50Hz. Or Zout circa 6mOhm.
Someone have the files for the LTspice simulation ?
I would like to check the Zout value.
I am not near my computer to post the file. However, this amp is so darn simple,
you should be able to type it in 10minutes. The model for the LU1014D is there at the bottom. Nothing missing if you have Cordel models.
Well, it seems I got screwed by Aliexpress. One of the recommended suppliers sent me a mix of what are obviously different parts, all wrapped in a nice sealed strip. But at least three styles of plastic molding and different position of the text on the plastic. I really hate having to do full testing of each part, just to find some genuine LD1014 that may have accidentally been included.
Same here. Just got some in yesterday.
- LuFo Amp - 39w SE Class A from 28v Rail
