LuFo Amp - 39w SE Class A from 28v Rail
Founder of XSA-Labs
Joined 2012
Some progress by JPS64 on an Aksa Lender front end board for the LuFo. This one will use an on-board 55Vd DCDC converter. We will see if it is possible to make the DCDC converter in TH also.
Founder of XSA-Labs
Joined 2012
Is there a simulated data about Zout because cascode will increse this value.
The predicted DF was 156 at 50Hz. Or Zout circa 6mOhm.
Someone have the files for the LTspice simulation ?
I would like to check the Zout value.
I am not near my computer to post the file. However, this amp is so darn simple,
you should be able to type it in 10minutes. The model for the LU1014D is there at the bottom. Nothing missing if you have Cordel models.
954037d1621739943-lufo-amp-39w-se-class-28v-rail-lufo-triple-irfp240-v1-png
Well, it seems I got screwed by Aliexpress. One of the recommended suppliers sent me a mix of what are obviously different parts, all wrapped in a nice sealed strip. But at least three styles of plastic molding and different position of the text on the plastic. I really hate having to do full testing of each part, just to find some genuine LD1014 that may have accidentally been included.
