CRC PSU PCB GB
simon dart 2 nos-shipped
Tamura 3 nos-shipped
md_Stryker 4 nos-delivered
poseidonsvoice 4 nos-delivered
h3t65 6 nos-shipped
adsl 2 nos- shipped
diplomata 2 nos-shipped
Antsav 4 nos- shipped
odie1427 2nos.-shipped
twocents 4nos.- shipped
zlib 6 nos.- shipped
mario78 6nos.- shipped
speakes1 2 nos.- shipped
d to the g 3 nos.- shipped
h3t65 6 nos-shipped
adsl 2 nos- shipped
remaining PCBs- 0 nos.
we thus come to the conclusion of GB, thank you all and all the best in your projects with this pcb.I have run out of almost all pcbs that have LT4320 for rectification including those that can adapt these designs for rectification. The list includes
1. LT4320 CRC PSU PCB
2.LT4320 THT RECTIFIER
3. LT4320 SMD RECTIFIER
4. CRCRC PSU PCB (that can adapt no.3)
5. Compact 95x100 CRC PSU PCB ( that can adapt no.3).
If there are specific requirements , I can produce and supply those pcbs.
Let's see the initial interest and then I will create google sheet .
Prasi
Prasi
What quantity do you need to reach?It seems to be a low demand for the pcbs. I can't produce pcbs that are economically feasible at such qtys.
So I will keep this open for a month, and let's see if there is sufficient qty.
Prasi
Hi Prasi
I am interested in a 4-pin SIP drop-in FitFormFunction replacement (similar to interface and size of https://www.diyaudio.com/community/threads/lt4320-based-active-rectifier.336572/post-5759365). Is it one of the versions you offer here?
Also I would like ROHS traces.
Fab
Fab
Looks like number "3.LT4320 SMD RECTIFIER" is what you want.SMD version is intended to replace the SIP-4 type packages
Thank you guys for adding in your requirements. Good news is boardhouse is up and running from today.
Already placed the orders for the LT4320 CRC PSU.
Just about reviewing final designs for SMD and THT rectifiers before shooting the gerbers.
Here are some pics for LT4320 SMD. Everything looks good
shown here with MSOP package , DIP can instead be used.
Also shown are the headers spaced 5.08 mm apart.
The other header holes are compatible with SIP-4 rectifiers (PB3510). Also PCB size corresponds to Vishay PB3510 rectifier.
https://www.mouser.in/datasheet/2/427/pb3506-1767492.pdf
regards
prasi
Is this SMD PCB compatible with GBJ5006-BP rectifier too?
I want to change the rectifier of All Cee's PSU with this active rectifier.
- Group Buys
- LT4320 based active rectifier
