Hi guys, good to see people still playing with these. Anyway I might have damaged mine, not sure, thought I'd just post and see if anybody can help me.
the 2 wires ended up touching each other just after they come away from the board near the RCA plugs.
Well you couldn't have used thicker more problematic wire?
Musta been tricky not to have shorts with that stuff.
IMO good chance you've damaged the Ta chip.
Did similar when two speaker wires touched.. briefly.
These don't suffer ineptitude.. gladly.
IF you choose to Fix that thing, by inserting a fresh chip.. then DO wipe off the tone bits with a hot iron as they are Still in circuit.
And those wee electro caps are unlikely to be adding goodness 🙂
Bare
Does the wire thickness effect its ability to carry the signal properly? Or is there other reasons not to use such thick wire?
It was no problem to solder and it did not short, it was the previous wire that caused the issue I think.
OK thats about what I was guessing, I will get another chip and see how that goes.
When you say wipe off, do you mean remove the components?
I just noticed that the left right channels are reversed when using 3.5 mm jack input. Is this a well known issue on 2020+? I couldn't figure out why imaging was so much better with RCA inputs until I noticed snare drums switching sides under a/b testing. What a fat blunder on the circuit! 🙂
Interesting, should it matter what side is left and what is right?
It sure does if you want to recreate soundstage, otherwise it is like stage is upside down, but worse, if true directional xy mic were used the presentation will be really off sounding. Think about it like a 3d movie viewed with the goggles swapped left to right, doesn't have 3d effect anymore.
Not doubting you. Its just I don’t imagine a drum kit sounding any different if it was played upside down
reversed
Dude, I just checked my amp and you're right. All of the threads and expert comments on modding this thing, how to make it sound better, give it more bass, etc, etc and you're the only person to realize the 3.5 connector is F***ed.
I checked mine, and mine is fine (red board). What colour boards do you have that have it backwards?
Red Board
When I put a multimeter on the red (right) input of the RCA jack it connect to the left input on the 3.5 (MP3).
I noticed that my blue A+ board has the channels swapped. I too was hearing the strange imaging. I hadn't checked the RCA's. I just swapped the speaker outputs to correct it.
Yup, mine were swapped too. Simply switched them around when i installed new RCA jacks. (To keep the color-coding correct at least)
http://i.imgur.com/BbmPu.jpg
The RCA is fine, it is the 3.5mm that needs switching. If you switch the RCA's to match the 3.5mm, they will both be wrong.
I must have a newer version with this fixed. When I change the balance, everything is correct. My speaker outputs are wired correctly.
If you want to be sure everything is correct from PC to speaker, you can use: Speaker Test (Left and Right), Ensure that your left and right speakers are connected correctly. - YouTube
A_Backwards
Red Board
A dremel to cut the traces and P2P wiring will fix.
Red Board
I am too lazy to eff with it - I will just use a 3.5 mm to RCA cable and avoid the input 😀 Incredible how something like this makes it pass the circuit routing Q&A before going to production. But hey, who's complaining because the whole thing costs $20. It costs me $70 to fill up my car with gas so I keep in all in perspective 🙂 I am glad mine wasn't a solo lemon board though.
Why not just reverse the speaker leads? You don't need an adapter for that.
Mine has the input fixed:
That works too. You have to remember that it is switched if you go back to RCA inputs. With my way of not using the 3.5 mm input, it will be correct... But you have to remember not to use the 3.5 mm, so maybe it is the same thing. 🙂
pre amp section
I've had a couple of the NOS 6111WA tubes collecting dust. I found a decent schematic for a preamp and built it into my Gainclone. With a gain of 20, it added a nice little boost to the GC and a slight 'crispness' (to me) of the LM3886. Not going to tear it out of the GC but would like to build another to replace the sad opamp section in the Lepai. I can see using this Lepai board like Mardis did with the original T-amp. Mount it in a slightly larger enclosure and add a couple 10k uF caps to the resevoir cap, 2.2uF input caps and off board all connectors, switches and volume pot to better, case mounted dealios.
Tell us your plans!
Tell us your plans!
Tamasic,
Wanna share the tube preamp circuit and photos with us? I have sometimes thought of making a faux class A manly manly man amp with huge heatsinks and thick slabs of aluminum on the front with galvo gages and lights but with nothin but a measly class D TPa31xx inside, or a Tripath 2020. 😉 Have a class A aficinado listen in an AB blind test and see if he can pick out the real class A ( without touching the fins to see which one will burn his hands).
Tamasic,
Hey xrk!
I'm going to cobble together something similar, except I plan to build an ultra-low budget hybrid integrated (tube pre and 2020 power).
I already own a 2020 and I have ordered a $21 "YJ" single 6N3 pre-amp kit, some switches and other small parts, an $8 power supply, etc. About $33 in total. Going to bypass the volume control on the 2020 (already bypassed the tone and opamp) to turn it into a straight power amp and then wire the pre-amp directly to the 2020. Stick it all in a homemade chassis and maybe even integrate a USB DAC.
I don't expect it to challenge an expensive amp, but it'll be fun as hell to build! 🙂
- Class D
- LP-2020A+ mod thread
