LM317 load capacitance
We can attach very little significance to "I added an opamp and now I don't like the sound".
Regulator datasheets often give output impedance, noise, ripple suppression. What else do you think you need which "pertains to audio quality"?
Maybe:
Bandwidth
Damping factor
It's not just the characteristics of the IC, but the whole circuit.
Particularly when the implentation differs from the datasheet suggestion significantly.
Personally I'd attach more weight to measuring an effect than just disliking the sound.
OH?
This circuit appears in the Nat Semi Power Management Handbook, but I picked it off a website. If you look at the impedance curve of an LM317 without any output cap you'll see it has a high-Q peak:
That does not count, it has external feedback via the reference pin.
Unconditionally stable means only that a device is stable with any
combination of input and output impedance, as long as the
terminations are passive and do not provide external feedback.
The LM317 is well-behaved if it is used according to the data sheet.
For very large capacitors on the output it may require protection
diodes, so it cannot be powered from the output side when the
input voltage drops too fast.
but have you built and tested one?
hmm talking about load caps, 10uF ceramic X7R might set you back sum.
Anything that claims RF VCO in their sales intro (data sheet) is bound to be down there.
Too bad Jim Williams never used it his noise test jigs to replace his D cells.
I have measured the 3042, the 3045's little brother, against the rest
of the crop. There is one clear winner.
< VoltageRegulators | Output noise of some voltage regulators.… | Flickr >
Jim Williams predates the LT3045 :-( and his D cells were better anyway.
The influence of X7R is vastly overestimated unless you live in a helicopter.
That you have only half the capacitance in real live with the even lesser
dielectrics is a different story.
There are more interesting measurements on the Flickr page (left&right arrows)
I have used LM317 and LD1084 with 20 000uF input and 10 000uF + 0R1 output with few problems and very low noise. I did fit the diodes as per makers recomendaton. I used a 2A fuse as a Pi filter with 2 x 10 000 uF for the input. The fuse made a small useful improvement and I wanted a fuse. I had the recomended caps close to the device. I also used 470 uF with the feedback circa 2K ( 240R fixed value ). I felt it did no harm and was slightly better than 10 uF. The 0R1 started at 10R. Apart from useful current and drop out voltage 317 and 1084 seem identical in the same circuit.
My feeeling is a PSU made this way is using the regulator like we would a small engine in a hybrid car. If you like my output 10 000 uF is the electric motors in the anaology ( a car might only need 20 BHP average ). Having said that I fully realise 1uF would already be doing plenty and the regulator works mostly between circa DC and 1 kHz. I have real doubts a shunt circuit would beat this. If you see the picture. The regulator is doing as little as possible and parts are cheap. Add them as batteries if you like to remove need for using LM337. All you need is separte windings, rectifiers and caps. I measured no obvious problem doing this. You add plus to minus as the 0 volt common rail.
LM317/LD1084/LM78 series are very forgiving.
In my world, unconditional stability is quickly made void by bad grounding.
Which makes it easy to talk at cross purposes when you look at an IC which has no ground pin.
There is much talk of microvolts of noise. We build amplifiers with milliohms of ground impedance, then pull current from them.
A regulated power supply is still just a power supply.
If you want it to be a broad-band voltage reference, that's really a different animal.
