And, if you guys scoop all these up, be sure to save a pair for me. 🙂
I'll have additional info on the next hangout...whenever that happens.
Hi Michael and Diyers
Excellent they are one more sit´s reference to play with 182ES.
Ok imagine they are cheap birds and in stock on Mouser
Thanks for test councils Michael and to Psz to clarify doubts.
Let´s back to working sits on my table 5 pcs only not full box.
Michael i can share my bread and cheese one pair for Lab Hangout benefit.
Could be better pm this evening via email ?
Christophe
Very kind, but let's design and build your amp first. 🙂
And if you're still willing to part with some after that, I'll happily buy a pair from you.
Nevertheless, you're always welcome to email me.
I have good news.
PSz sent me some of his 2SK182ES for testing and they look great!
So, my parts were bad, as I suspected. It happens. I will drown my sorrows in a beverage of some sort.
Here's what a good 2SK182ES looks like:
Micheal,
I would have PM'd you, but that's apparently disabled for your account?
Anyhow, I was stumbling around and opened an unlabeled door and landed on this thread. 😀
What I wanted to comment on is the curve traced results?
Not sure exactly, but IF you take the posted images rotate them 90 degrees (and for ease of comparison) mirror them, they look remarkably like almost all other "regular" solid state devices... of course I am presuming that the axes are not merely flipped on these curve tracers?
No, the axes are correct. That's the magic of these devices. They are more like triodes, in that they have an unsaturated drain characteristic (sort of like having a much expanded ohmic region in the devices you're used to looking at)
I disabled PM. I prefer email mike (at) audiohobby.com. It's just easier for me to respond to questions and such in one place.
Thanks for popping in 🙂
to ur sig file, yes... it's not in ur profile though... you could add it there also.
I did not think the axes were flipped, but I was remarking on the visual similarity if one looks at it from a different "angle".
lets get down to business!
So since these devices seem very similar with tubes, at least their curves, what if we treat them like tubes in the old fashioned way? Lets say 300/V0,5A 700Ω loadline? Only negative about it is the input capacitance but this can be also solved by a good preamplifier. Am I missing something? Huh, I am missing the SITs as I already got the transformers and regulated power supply😡
Of course, I simply clarify for the sake of others stumbling upon the discussion.
So since these devices seem very similar with tubes, at least their curves, what if we treat them like tubes in the old fashioned way? Lets say 300/V0,5A 700Ω loadline? Only negative about it is the input capacitance but this can be also solve by a good preamplifier. Am I missing something? Huh, I am missing the SITs as I already got the transformers and power regulated supply😡
No, you're not missing anything. For example, see Ironamp. As long as you stay within the power ratings and so forth, you can try lots of things with these.
Website and Email added to my signature. Did it work?
yes , for that post and later ones
how it doesn't work for all your previous posts ?
Yes, indeed, it must not be a global setting. Interesting, each message must have it's own "show signature" boolean.
I had it turned off for a while, oops 🙂
The output curves show a linearity similar to that of a vacuum tube to direct heating. there is an output transformer that interfaces with these devices?
BTW, what sort of speakers will you be driving?
Hello Michael
3 pairs:
first low efficiency ~ 88 dB with crossover
midle efficiency ~ 92 dB with crossover too
full range ~ 98 dB ( no filtered )
all are 8 Ohms
Choice
Thanks Michael! Watching the 182ES work with much interest. Enjoyed #4 a lot.
My long term building plan
JFet - Aleph J amp - done
VFet - CX-1 is next up, after I finish a DDDAC
SIT - with 182ES will follow
Still looking around for a 2a3 or 300b schematic that strikes my fancy.
- Live Lab Hangout #1.1 Posted
