Live Edge Dipoles - #1 at Parts Express 2023 Speaker Design Competition - Updated Design
Just figured I'd post a progress pic on my bitches brew's. You can see I have adapted the top driver for the 14.
Superb wood craftsmanship Subsonic!
Best,
Anand.
Thanks Poseidon!
I really like how people are making this design their own, with thoughtful variations and excellent craftsmanship.
I also think it's neat how this design lends itself to small variations. Balthazarp's version looks quite different than yours, and mine is another version all based on the same base design. I still have my reservations about the minidsp unit possessing hardware that is good enough to do these speakers justice, but it's extremely cool that you can just make alterations to the active crossover to account for these design changes. My version will also have some removable wings that will fit in the open areas of the bass drivers to see what kind of bass extension I can get. I'm also toying around with the idea of making a single detachable side wing for the coaxial driver to see if having one wing will have a positive effect.
I should be getting a lot of work done on mine over the next few days. I might have a pair of working speakers by Monday or Tuesday. I'll need to familiarize myself with the MiniDSP software. Unfortunately, right after that I leave on Wednesday and will be out of town for 2 weeks.
Reactions: perrymarshall
To heck with the speakers, look at that amazing shop!! 😍😍😍
Ok, so the speakers are looking pretty damn sweet as well. 😏 Were the baffle angle variations driven by aesthetic preference or by a hoped for performance gain?
Thanks dayneger! Yes, my shop is my "happy place".
So the baffle angles are an adaptation of the original bitches brew design that, as far as I know, was originally done by balthazarp on this forum. He has a picture of his speakers posted over on the Ultimate open baffle gallery on page 211. I took inspiration from the original design and balthazarp's adaption and mixed in some of my own design ideas to come up with the version you're seeing. As far as the baffle angles are concerned, first, I just think it looks cool. But second, I'm very sensitive to vertical off axis changes in the tweeter. The original design had the tweeter tilted back at 10 degrees (Perry has since said he would recommend a 5 degree tilt instead of the original 10) and the center of that coaxial driver is about 42". By angling the bottom 2 drivers as well as reducing the spacing between drivers to an absolute minimum I shave off about 1.25" off the tweeter height. But probably more importantly for me, the tweeter is now facing straight ahead instead of tilted back. I've never heard the original design so I have no idea if this is any kind of an improvement. Maybe it's worse. But for me it was worth it to try this for the potential benefit - plus I just like the aesthetic as I said.
I also built removable crossover boards which will house some Neutrik Speakon chassis mount connectors for the speaker cables.
The baffles are super rough from the drum sander in these photos. They will look quite different once they are all sanded up and finish is applied.
Hi @perrymarshall. I haven’t been on the site for a while and just catching up on your new designs. Fantastic! Always learning new nuggets from your write ups.
I’m actually going to build a dipole now because I’ve gotten into guitar/bass and was going to build a pair of 2x12 cabinets. But then I thought I might as well make them proper dipoles since guitar speakers are typically designed for open backed cabinets anyway (or large sealed volumes). And then I thought I might as well add a horn, so I can use it as an active full range speaker with a DSP config change.
So I’ll be mining your papers for ideas.
One question I had is on the use of the angled u-baffle wings on your designs. Have you seen this analysis? I’m sure you are aware, as I believe I’ve seen your reference the resonance that results.
So my question is: what is your take on the tradeoffs of the directivity ripples at around 150hz, 300hz, etc vs the added bass extension you get from the wings? Is it that you think room modes dominate more down here, so the added octave of bass is worth the trade off? Or have you found a way to side step the issue?
That analysis makes me lean toward using just a wide front baffle. Probably wide at the bottom and tapered toward the top. I’d still have wings for support, but I can make the triangles hollow. This should get me down to bass guitar range, but I’d need to add subwoofers for anything really low and loud.
This post by @nc535 speaks directly to your question.
The radian 10 has the exact same tweeter as the 8. So the only difference is the extra surface area of the larger cone and the extension to slightly lower frequencies. I haven’t used it but I think it would blend better with the 18 inch sub than the 8 does.
I think the 5208 has a slightly better top octave than the B&C drivers, which have titanium diaphragms. I would love it if they offered beryllium or Textreme.
The B&Cs have a very slight tinge of harshness, unless you have a really good amplifier. Then it goes away.
Despite that, I feel like the bitches brews are overall better integrated than the live edge dipoles. They are more seamless.
The 15OB350 + 5208 will sound great, no question. To anticipate your next question, 15OB350 + 5210 would probably blend a tad better and still have the beryllium high end. I think the extra surface area all by itself is a virtue.
One 15 all by itself will start running out of gas below 30 Hz in most rooms. The 5210 with a 21 inch woofer would go all the way to 20Hz in a dipole.
How dare you anticipate my next question? I feel as though part of my unique agency as an individual has been untimely stripped!! 😳 Jk, of course. Feel free to ignore my feeble attempts at humor.
I do wonder whether the 10" Radian 5210 would blend better overall, or end up not be as great in the midrange as the 8" 5208... at least when paired with something like the SB 150B350, which seems to represent amazing value for an OB mid/woofer.
One of the aspects I enjoy about your project descriptions is designing around constraints. I've developed physical products (but not audio gear) professionally for more than 25 years and deeply appreciate the duality of inspiration and PIA inherent in said constraints.
A complex constraint system for a future project could be:
1. Assume monopole bass below around 50 Hz via 2-4 sealed servo subwoofers
2. Allow the power and cost of DSP to enable a vector toward the highest possible performance
3. Target a (relatively) modest initiation cost that can be upgraded for higher performance over time, if needed
4. Design for a more ephemeral, confidently there but visually lighter/less "line of sight-dominant" aesthetic than rectangularish slabs afford
5. Retain the Constant Directivity aspiration to the extent reasonable given 1-4
We'll just state right now that I have absolutely zero personal interest in the above product requirements document whatsoever! 😉
Perry, thank you for all this great info on these speakers. Using a Flex 8 and tri-amping looks like a nice way to go. Learning how to use IIR and FIR filters seems straight-forward with a few sites providing tutorials.
Two questions:
1) I did a preliminary search in a local slab supplier and found a beautiful pair of kiln-dried walnut slabs, but they may be a little short. The ends are rough and have a couple of splits, but the manager said he or I could fill the splits with epoxy. Just how low can the center-line of the Radian coaxials be and still give great sound?
2) The Radian coaxial Be do cost quite a bit to get a pair of speakers built. I noticed Radian recently added a line of coaxials with ribbon planar tweeters here. They seem like they may have an excellent smooth sound, but I cannot find anyone who has used them yet to verify. The 10 inch LF only cost about $50 more per driver, so the 10 inch coaxial seems the way to go. Your thoughts?
1) If you stick to the design as drawn you could move the center of the coax down to about 28" off the floor, making the front baffle ~35" high. I wouldn't make it much shorter than that.
2) The coaxials with ribbon planars are probably great drivers, the caution that I have from looking at the specs is that the off-axis dispersion above 10KHz is not nearly as good as the compression drivers. Seems to fall rapidly beyond 15 degrees off axis.
3) The Radian 5210 is a great way to go. Obviously will require some tweaking of the crossover.
I think a 5210 on a baffle that becomes narrower at the top (with corresponding EQ boost 150-500Hz) will blend very well with the 15OB350 and handle the EQ boost better than the 5208, and be more visually to your liking.
Thanks Poseidon!
Ok, it's Tuesday... waiting impatiently for your update before you leave town! 🙂
And still lusting after your shop.
Haha, thanks dayneger! I spent all day yesterday sanding 😢. Both speakers are almost done, but not quite! I won't be home until Christmas and then there's... Christmas. So I'll probably be able to finish them the week of Christmas. I'm bringing the crossover boards with me while I'm away and will be working on soldering up the crossover networks to be making SOME kind of progress while I'm gone.
As an aside - looking at these B&C drivers, they use the spring loaded connectors. That seems an odd choice for a high end driver. I'd like to be able to solder to them, especially since my hook up wire is solid core. Anybody ever disassembled the spring loaded connector before and somehow soldered to it?
