If you think of an old 16bit dac, you are probably right, if the volume control is badly implemented. For a modern 24 or 32 bit chip it looks different. If the wordlenght is 24 bit, you have 8 bits to give away with a 16bit CD, the same for a 24bit download a 32 bit dac.that's the way a digital (bit control) volume control works.
You can either chop off the most significant bits or chop off the least significant bits. At low enough volume your 16bit signal becomes 8bit, or even less. All the low level information is buried in that bottom bit.
One bit means 6db, you can attenuate to (8 times 6db) 48 db, lossless.
And there is more. Read the very interesting
"White paper on digital level control"
by Daniel Weiss
ComputerPlayback
Nevertheless I still use analog level control, because of my vinyl....
Andre
Absolute precision down to fractions of a dB is not required for musical enjoyment. None of George’s customers have complained about matching problems. A well-matched set of LDRs will work fine in practise.
It's simply impossible to match such components and expect any constant matching on the time. Its own physical principle wouldn't allow such a behavior... Unfortunately, and you can easily verify this by constantly measuring the values for different attenuation ratios.
I mean you no disrespect, but your conclusions regarding distortion levels, is perhaps misguided. Some distortions can be tolerated at surprisingly high levels whereas others can be annoying at much lower levels. The LDRs do not generate any annoying distortions to my ears (and many, many others). There will be far more objectionable distortions to deal with in the rest of the system and with room interaction.
It's well known that some "special distortion" will even "improve the audio quality perceived" this is used in several amps, like some AKSA models and other... Then, even distortion can be "tolerated" or moreover "subjectively improve audio", this is not acceptable at least for my usage... And for obvious scientific reasons !
We built a very large panel of attenuators from very expensive pots, to the LDRs controlled by ADCs going through TVC and several other solutions. The last more reliable, distortion free, and musically totally transparent attenuators are very high precision resistors with relays, period.Whilst measurements are useful for gauging general performance, the final arbiter for me is, does the equipment give me a convincing illusion of a live performance of real musicians. Of all the volume controls I have tried, George’s “Lightspeed” configuration gets me the closest to my live music requirement for any volume control I have used in my system. It is just so damn musical in all the right ways. I do not care if the measured distortion level of the LDR is relatively high.
We probably are not speaking of the "same distortion"... For example, with a very high feedback loop, you could reach very low levels of harmonic distortion (even lower than those of your AP device...). There are several types of distortion. Some are more important than other. But anyway, it is preferable to maintain ALL types of distortion as low as possible !I have tried so many items of equipment with extremely low distortion measurements over the years that are simply incapable of reproducing good music in an enjoyable way. You know the type. They are so disturbing and annoying to listen to, they take away the desire to listen to music.
Unfortunately, it would not work in every case, if you are in balanced mode with long links between the preamp (attenuator) and your active monitors or your amp have insufficient input impedance, etc. you'll face some difficulties... And finally, the argument of listen fatigue is not acceptable, since I know a lot of gear with this facility and high distortion, again, even physiologically acceptable this is not the right way : but I respect every one deciding to follow it. This is just my personal result after several years of "perfect attenuation" research. No more, no less.The “Lightpeed” is ridiculously simple, ridiculously inexpensive, works very well indeed and does not cause any listening fatigue. 🙂
ondesx:
Have you listened to a Lightspeed or a clone? What were the test conditions? Sources, power amps, speakers, source material, etc.? What sonically did you observe as the defecit when comparing your LDR attenuator to the product of your "perfect attenuation research"?
When you performed your testing of the LDRs, when you observed variations from test to test, what were your lab conditions? Did you check each LDR at the same temperature each time? George has repeatedly stated the importance of potting the LDRs for thermal tracking between them. Is this what you did? Did you select and match a quad, or a pair, then pot them and re-test at a later time at the same temperature, or did you note the temperature change? Air blowing on the LDRs affects their resistance. Did you encase the LDRs when testing to assure that was not the cause of the variation?
A common claim made in this hobby is the notion of a "distortion" which makes the listening experience more pleasant. That concept used to deride both the individuals using the distorted technology as well as the equipment: i.e., "You guys just like the sound of this distortion without realizing that it's a distortion that you like. We enlightened people don't fall prey to that fallacy." From my own point of view, improved clarity, resolution of low-level detail, a stable "sound field", reproduction of high frequencies without an added "edge" (which is not present in live, unamplified music), bass without boominess, but with excellent definition do not count as distortions.
Whatever your ideal stepped attenuator form is, will you be willing to set up a demonstration, comparing it to the [euphonically distorted?] Lightspeed, or a clone? I'm sure some participants in this thread must be near enough to you to make such a comparison a reality. You could really show us something.
Stuart
Stuart
What do you do with yours then and what exactly are the scientific reasons ?
Is it anything to do with music reproduction ?
and where is AndrewT when we need him ?
Andrew
you don't need me.
I see you fighting from your corner pretty well.
I have been in the background watching and waiting for developments.
Let's see justification !
AndrewGM maximus sepolansky AndrewT
Thanks guys, saves me from having to say it for the millionth time.
Cheers George
Cheers George
We build several models of this attenuator even a balanced version and an auto-calibrated one... For the measurements, we used an AP. For the subjective audio comparison, I'm afraid we only have our ears... But this is the same for everyone isn't ? Unfortunately, the distortion observed with the LDRs was expected since it's one parameter of the component you can easily retrieve in the DS...Have you listened to a Lightspeed or a clone? What were the test conditions? Sources, power amps, speakers, source material, etc.? What sonically did you observe as the defecit when comparing your LDR attenuator to the product of your "perfect attenuation research"?
I think the measurement condition are standard. Casing or not for an iterative measurement of the currents needed for a given attenuation show variable values what ever you do. Moreover, these components work on a statistical basis and by construction don't have a correct linearity. With the calibration we have observed that whatever the time used for doing it (from one hour to one day...) the audio results AND measurements are more or less... the same !When you performed your testing of the LDRs, when you observed variations from test to test, what were your lab conditions? Did you check each LDR at the same temperature each time? George has repeatedly stated the importance of potting the LDRs for thermal tracking between them. Is this what you did? Did you select and match a quad, or a pair, then pot them and re-test at a later time at the same temperature, or did you note the temperature change? Air blowing on the LDRs affects their resistance. Did you encase the LDRs when testing to assure that was not the cause of the variation?
Unfortunately we aren't speaking of the same things... Subjective considerations are one point, but have nothing to do with scientific measured parameters. Both ways of development are respectable. I just recall the drawbacks of the LDRs and give here our own experience after a couple of years playing with them... It's normally the way a forum will work. Isn't ?A common claim made in this hobby is the notion of a "distortion" which makes the listening experience more pleasant. That concept used to deride both the individuals using the distorted technology as well as the equipment: i.e., "You guys just like the sound of this distortion without realizing that it's a distortion that you like. We enlightened people don't fall prey to that fallacy." From my own point of view, improved clarity, resolution of low-level detail, a stable "sound field", reproduction of high frequencies without an added "edge" (which is not present in live, unamplified music), bass without boominess, but with excellent definition do not count as distortions.
I'm afraid most of the participants are far from me. I'm in France as shown by the banner... Don't misunderstand my input. I'm not saying that the audio result with LDRs is "bad", but it's just better doing another way...Whatever your ideal stepped attenuator form is, will you be willing to set up a demonstration, comparing it to the [euphonically distorted?] Lightspeed, or a clone? I'm sure some participants in this thread must be near enough to you to make such a comparison a reality. You could really show us something.
I explained that in some situations (for example low input impedance of the amps) the audio results will be poor. And as a direct consequence this preamp wouldn't give pristine result without a good buffer... But anyway, with the figures of distortion observed with the LDRs I couldn't derive a high quality audio preamp... Again, this is my personal point of view. Obviously, everyone could have another opinion !
To AndrewT :
This is the message I received from your mailbox...
AndrewT has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Then I ask through the forum what would you see to be posted AP measurements, picts of the preamp ?...
...what exactly are the scientific reasons ?
Well to illustrate this point I'll just use a very well known experience in the visual domain. If you take two squares of the same color or the same gray level and included each one in a different environment (one in a darker one and the other in a lighter one) you can have "subjectively" the illusion that these two squares are of a totally different color...
But the truth is that they are of THE SAME color whatever you are observing !
Scientific colorimetry measurement of the squares will show that both are of the same color or gray level, even if nobody will believe such an evidence...
what about the linearity of the mentioned circuitry, especially for larger amplitude (say >1V)I've played with every concievable passive pot, Bournes, Alps Blue Velvet, Alps Black Beauty, Penny&Giles, Dact Switched resistors, and transformers.
Nothing has beat the sound of a series/ shunt LDR arrangment in the attachement, it has no contacts in the signal path, I believe that is the secret.
The only stipulation that all these passive controls including the series/shunt LDR need I believe is,
1: Low source impedence (cd player) <200ohms
2: High input impedence (amplifier) > 50k.
Cheers George
So now would be a good time to stop trying to prove your superior subjective results and leave this thread as you seem happy with YOUR results?
rgds
jms
rgds
jms
This is definitely an unacceptable behavior in a decent and well administrated forum. I ask the moderators to recall to you the rules of this forum. I don't try to prove any superiority, but I report here our own results experimenting with this component.
You may have different results and in this case you can report here your own experience, but please avoid in the future sensitive posts like this one.
...You may have different results and in this case you can report here your own experience, ...
I posted mine here...
Can you explain the specifics? What have you taken into account in the various designs? I have listened to some commercially available LDR, they certainly are much more clean and detailed in sound lack of hash that normally is associated with pressure contacts....
Thought digging up the past would be interesting. It was...
A few quotes from a very satisfied LDR listener:
Probably the most intersting in light of more recent posts is this:
Finally and as recent as the last 24 hours is this
NOW all is perfect !... The pot was faulty (why ????).
No more crackling no more echoes, just THE music !...
Again thank you George you are indeed a great guy !
Hope a lot of audiophiles have the opportunity to build this really amazing interface !
All The Best to everyone !
Stop the match please ! Everyone interested in the best solution must do the comparison by himself...
It's very easy to do btw. You just have to use a couple of CDs (same of course) and fix a listening level (of course again you need some stuff to work with, here a sound level meter will be useful). Then you have to measure the series value of the LDRs. You can do two experiments :
- the first is to replace the "free" LDR with a LDR fed by the current giving the "same" series value.
- the second is to replace the series LDRs by the equivalent resistors (you can use the highest precision you may find).
Thats all folks !
If you guys still didn't hear any difference, stop high quality audio and buy any Chinese low cost integrated amp after go drink all the saved money !...😀
My Very Best to you all,
Well, I tried to match my 20 NSLSR2S but it seems not so easy in practice...
Has somebody 5 minutes to explain how to do this match in a very simple way...
I have a 5 V DC regulated PSU.
TIA for any help.
For those who are interested in the "comparison" of different LS flavours...
First, as stated several times by GeorgeHiFi, the MKII version won all comparison with both MKI and MK1.5. Whatever the resistors used the worse are SMC.
I couldn't measure impedance values easily and the only achievable data was the resistor value for series before inserting the module in the audio system.
All the parameters are better with the MKII version, sound stage, transparency, resolution, harmonic structure of the instruments and voices, etc...
I definitely don't explain why, but in my system the MKII version was the large winner.
For the P&S LS OPC271, I asked to these guys several months ago and the answered that they used LDRs in series and shunt, then it's also a... MkII version ! After my request, they offered both single-ended and balanced versions. The price falls slowly and I hope it will be available at a decent price in a couple of months... If everybody send a mail to ask a better price, this will probably boost the fall...
I used two different PSU : one for the "fixed" series LDRs and the other for the shunt LDRs... Both are regulated by the same 7805s !...
I don't believe in a noise issue, but...
@George !
I finished my balanced Lightspeed MKII following the schematics and the directions you kindly provided. The beast works really amazingly after the last connected wire ! Even without any tweaking it outperforms my last auto-former interface without any doubt !...
Despite the 10 K input impedance, the output levels reached are largely enough. I think that aside the impedance problem, one other parameter is of some importance : the sensitivity of the amps. With very sensitives amps the Lightspeed will perform much better... I tried with two different amplified monitors both with 10 k input impedance, the results are much better with the one displaying 100 dB SPL for -6 dB !...
Then, please can you tell me how to tweak the 1K variable resistors to optimize this indeed beautiful and incredible interface ? For low levels I noticed a degradation of the audio quality (disappearing for louder levels), do you have observed this problem previously ? And of course, any suggestion to correct this will be welcome...
Thanks for this and for all the support you already provided to everybody on the present thread !
My Best.
Thank you James. I did a try before going to bed yesterday night with a very simple operational amplifier mounted in follower mode (a couple of LME 49720) and the observed phenomenon at low level remain... I concluded that there isn't an impedance issue !
Moreover, the impact and intensity of the lows are just amazing, that wouldn't be the case with an impedance mismatch, or this mismatch just appears for low levels ?
Perhaps somebody knows what happens if one use a too high or a too low power supply ? Anyone tried batteries instead ? With a charger, it'll be perhaps the best solution isn't ?
I'll try with different PSU now and we'll see...
For an enough high level, all is pretty good, the sound is just incredible, better than with my third opus of auto-transformer (which still reached a very very good audio quality indeed, much better than most active preamps, even some swiss made costly gear...). We have more presence, transparency, the sound stage is very large, the voices are more natural, with a very good stability for high frequency at high levels, the dark side is the mixing errors are more evident too !...😉
Enclosed a picture of my first balanced LS opus !
- Analog Line Level
- Lightspeed Attenuator a new passive preamp
