Lightspeed Attenuator a new passive preamp
I've tested and listen to just about every concievable passive potentiometer (volume control), Bournes, Alps Blue Velvet, Alps Black Beauty, Penny&Giles, Dact Switched resistors, and transformer (TVC) based volume controls.
Nothing has equaled the transparency and dynamics of sound than that of a series/ shunt LDR arrangment in the attachement, it has no contacts in the signal path, I believe that is the secret.
The only stipulation that all these passive controls including the series/shunt LDR need I believe is,
1: Low source impedence (cd player) <1kohm
2: High input impedence (amplifier) > 33kohm.
Cheers George
8-3-2015
To explain a little the 5 photo attachments.
1st: Is the basic led/ldr and how it works in the Lightspeed Attenuator, it mimics a 10kohm series shunt logarithmic potentiometer.
2nd: Is the Lightspeed Attenuator stereo version, complete circuit diagram, note how the signal goes through nothing but one soldered resistor, no sound robbing light contact of a metal wiper on a resistive track in a volume control (potentiometers) in the signal path.
3rd: Is the same but a dual mono, good for room or system imbalances, (for some reason owners of both say the dual mono has the edge sound wise) I believe it's the fact you can precisely centre the image regardless of recording or environment influences.
4th: Is the buffer Nelson Pass designed a few years back for the Lightspeed Attenuator (later to be known as the B1 Buffer) for it to be able to drive low input impedance amps of less than 33kohm.
5th: Is the $30 Kemo M087N led tester you can get on Ebay. With this you can quad match your own set of NSL32SR2S(sorted) Silonex led/ldr's you'll need get about 15 pieces to get 2 sets of quad matched led/ldr's for two x stereo Lightspeed Attenuators. So go halves with a buddy and you can have one each.
Match the LDR resistances using a DMM, powering the LED from 1mA to 20mA, give them time as they need a few minutes to warm up.
PS: You can skimp on the cheaper NSL32SR2 but you have to buy almost twice the amount, as their low resistance is not as low and constant, they cannot get to quietest minimum volume level as the NSL32SR2S (sorted) can.
Cheers George
  • 2_lightspeed-attenuator-new-passive-preamp-lightspeed-attenuator-mkii-circuit-diagram.jpg
  • 3_lightspeed-attenuator-new-passive-preamp-470084d1425721076-lightspeed-attenuator-new-passive-p.jpg
  • 4_lightspeed-attenuator-new-passive-preamp-470085d1425721076-lightspeed-attenuator-new-passive-p.gif
  • 5_lightspeed-attenuator-new-passive-preamp-470086d1425721076-lightspeed-attenuator-new-passive-p.jpg
Use a dual 100k log or linear pot to supply the voltage to the leds, one gang of the pot increases the series ldr's led voltage while the other gang in reverse lowers the voltage on the shunt ldr's led, this way you have a constant input and output impedence of the passive, regardless of where the voltage control setting is. I believe it's the perfect passive volume control.
You can put an LRD in one end of a tube and a Led in the other end x 4, you have to sort through a few ldr's to get 4 that track together for good channel balance, the last thing you want is to have a balance control, but even that's possible if you use two single 100k led voltage pots instead of a dual.
Cheers George
1: Low source impedence (cd player) <50ohms
2: High input impedence (amplifier) > 100k.
Thanks George, I'ma very bad at electronics, so I'll try to sort it out. For example, I don't remember if LDR increases or lowers resistance with increasing light.
This type of control perhaps should be put after a buffer (attenuating buffer's self-noise) but I understand that impedance matching would be wrong, isn't it?
You should look for a LDR who's led on resistance is around 50ohm and dark resistance around 1megohm.
Also the balance control that I said would be 2 x 100k single pots for the leds is wrong, it would have to be 2 x 100k dual pots.
Also you could have a LDR in each end of a 1inch tube and the LED through a drilled hole in the middle, that way you'll only need 2x tubes for a stereo control.
There are combined Led/Ldr packages out there, but they are very expensive and you still need to match them.
And forget about using buffers before and after the LDR control, been there done that they only add their own colouration to the sound. A CD players output drive is plenty capable of driving a amp to clip, all you need with the LDR Control is to keep the interconects to the amp as short as possible, <2mts and to use ones that are <100pf per foot.
Cheers George
gfinlayson said:
George, do you have any manufacturer's part numbers for the LDRs? The lowest values I can find are about 2 kohm when illuminated.
They are out there, you'll just have to do your homework to find them.
I make these LDR Volume controls ("Lightspeed Attenuator") as a source of income, I started them 30years ago, but back then the ldr's were way out tracking wise and changed their resistace curve with use, you needed 100 to match up 4, then I shelved the idea. In the late 90's Melos bought out their flagship preamp the SHA-Gold-Reference $20kUS which used the ldr's (hailed as the best sounding preamp ever, probally because of the ldr volume), still unreliable, nearly all that were built came back to them, maybe this is what sent them broke.
But now there are ldr's which can be 100% reliable(you still have to sort them 10 to get 4 to track), you will just have to search for them like I did, then you will keep it under your shirt like I am, because if I tell everything it will effect my sale of my
"Lightspeed Attenuator" units.
Cheers George
Al,
The heretical line stage is very good indeed; transparent, detailed, very smooth. I'm just curious to compare it with a good passive. The LDR passive seems a very simple, low cost way to try it out.
I'll probably end up building a heretical line stage anyway, if you're happy to share the design.
Graeme
Quote:George,
please can You tell how equal in which range Your stereo-attenuator works?
Heinz!
Heinz, my attenuator after calibration is at worst +- 1db from min to max level at best I can achieve +- 1/4db from min to max level if my ldr matching is good, I use a 25 turn 500ohm pot in series with the led resistor on the strongest channel to calibrate this, it could almost be used as a balance control.
Cheers George
georgehifi said:
Heinz, you did not look too hard at the Perkinelmer site, you will find one as low as 1.5ohm at it's max led current of 40ma at 10ma it's still 5ohm which plenty, mine are 50ohm (different brand) which is still great, it will not go to absoulte zero volume, but that's no problem to me as it is just a whisper.
Cheers George
George,
indeed, my "knowledge" stems from long years back experiments
with some "no name" LDR`s!
Heinz!
snip
Thank You George,
these results are very good for this simple arrangement!
But as You surely know it`s not really "hihi".
(I take the quality of a switched attenuator as a ruler.)
If I like to design such one with LDR`s I would try to insert
this passive arrangement into a servo circuit which compares in/output and steers the led`s.
A little bit simpler to do this can be the using of a high frequency
pilottone with a notch in the output.
Of course this is much more input so the LDR using lost its simplicity!
And of course one had to sell it for "$20kUS" :xeye: 😉
Heinz!
Probably I missed the point but I thought that LDR use had its advantage in avoiding contact and moving parts, not in being "simple".
High-frequency pilottone filtered out without spilling into audio band, i.e. by harmonics combination? :scratch: Doesn't seem hi-end as well
Well I suppose now I have to give my long winded explanation of why I believe it has beaten everything I've put up against it, here goes.
I while back a freind of mine who worked for the CSRIO (massive research company in Australia) borrowed a giga hz storage oscilloscope worth 10's of K$ and we started to do some experiments.
On all the best pots mentioned in my first post, what we found was that during fast pulsed millisecond transisents at cd levels, audio band squarewaves, then stored and reviewed frozen on the scope, the leading edge was getting corrupted sometimes ringing, this leading edge has a very fast rise time > 100's volts per microsecond, and what we found was that the wiper on all of the pots were getting bounced, if you like off their tracks during these fast transients, (it was as though the contact area of the pot had become a diode and it was trying to rectify the ac signal) if we pushed on the wiper to give it harder contact to the resistive track the corruption stopped. Naturaly this would wear out the track in no time with this pressure. This also happened to switched resistor pots and also input switches, though to a lesser degree.
Now maybe you all can see why myself and later on Mark Porzilli (of Melos fame) were so obsessed with getting rid of small area contact devices (pots&swithes) from the singal path as they give some form of transient distorion. Hence the use for us to the led/ldr arrangment(zero contact area)
And Graeme you asked
George,
Do you use anythig fancy for the 100k pots on the LEDs, or just standard carbon track items?
No nothing fancy mate, the good old $2 carbon pots will do fine, but a good super smooth regulated 5v supply for the leds is a must.
Cheers George
snip
....and how do You avoid the contacts of the connectors?😉
With "simple" I mean of course the difference between the use of
LDR`s alone compared with a additional servo arrangement.
Heinz
snip
High-frequency pilottone filtered out without spilling into audio band, i.e. by harmonics combination? Doesn't seem hi-end as well
In principle I agree!
On the other hand it depends from circuit design and the frequency....about 500kHz.
Heinz
snip George
How this??...after a 20kHz filter! Possible done through a internal
overload?
snip
I have never notice this effect, though I built (non audio) amps to 10MHz.
What about the contacts in the scope attenuator?
snip
In this case one need stronger/cleaner contacts!
snip
Why not, but at the expense of less stability and more non linearity (especially with high input voltages!)
For a "hifi" attenuator I`ll prefer therefore precision resistors connected with hermetically closed relays.
Heinz
