Totally calm, you've turned this thread into a merry go round. And it is helping no one, but your own ego.
Cheers George
Cheers George
It is a bit painful now.
I've never known a thread to go this far of course with such a horrible feel to it.
I frankly don't give a sh.. for this stuff now.
I'm trying to learn things and enjoy building stuff at the same time.
I love my Lightspeed - it's a whoie lot better than what I had before.
That'll do me - the figures just don't matter
Can we just quit now pllleeeasssee😡
Well, thought I do a little Googling and the first thing I found (I'm sure there must be many more) on the PS Audio forum is that our friend Ondesx has been accused of being a shill or working for a competitor to do some discrediting before. Paul McGowan one of the nicest people in audio the owner of PS Audio, wiped his hands of him as well.
PS Audio - High-Performance Home Audio Equipment
Cheers George
Cheers George
I mean all the test configuration you mention here.I'm sorry but I'm not sure to understand your request. The plotted curves are for the MKI i. e. for a series fixed resistance (this is the definition of the MKI) and the series-shunt LDR setup i. e. the MkII. The way both work is obviously well known in this thread. Then, what do you mean by "what other volume control configurations you have already actually tested ?" perhaps another valiue than 15K for the fixed series or a different total of the 7K (=series+shunt values) for the MkII ? Or perhaps are you asking for my last attenuator not using LDRs ?...
Secondly, what do you mean by "Simple shunt-series type configurations do not have linear gain" ?
Both setups are compared for THE SAME attenuation value (-24dB for the published curves) and the most favorable "total resistance" for the MkII. Then, the derived data are quite well comparable. I did the measurements for all the attenuation values allowed by these setups. I also published, in one post above, a couple of curves at 0dB (i. e. no attenuation). Obviously the differences are much more visible. These data point out, as expected, that :
- first, the MkII suffers for greater distortion than the MkI
- secondly, the MkI almost generates only even harmonics
- thirdly, the MkII almost generates only odd harmonics.
Depending of the attenuation level the number and the levels of these harmonics are different. But the rules remain. The reason of these results is related to the Fourier Transform of the output signal.
We built a very large panel of attenuators from very expensive pots, to the LDRs controlled by ADCs going through TVC and several other solutions. The last more reliable, distortion free, and musically totally transparent attenuators are very high precision resistors with relays, period.
Doesn't surprise me - nor anyone else I imagine.
It came as if from nowhere - ruining an interesting thread.
I'm absolutely certain I can't hear low levels of distortion but I do just happen to have perfect pitch, tune my own rather large piano and can observe improvements in my system large or small whilst listening to recordings of my favorite musical instrument - I can't explain that but I know it's something to do with my ears 🙂
My new attenuator ( courtesy of your design sir ) has taken me several large steps closer to this sound .
If your invention generates 2nd and 3rd order or other odd harmonics, peculiar harmonics or even weird harmonics ( joke ) it matters not when it sounds like this - not to me anyway.
It's all a load of bollock's 😀
Andrew
Andrew
By the hell, let me know what is ruined in this thread ? The hope of some businesses selling matched components and of very basic attenuators ?
If you're afraid for your money, then I understand the behavior of some of you.
If we're speaking about DIY then here are my results, like other did before me in this thread.
You say I come from nowhere, but you forget that I worked two years on this LS project and that some of these results are now established for a year ago !
Again I understand that you like the sound of your attenuator. Know the reasons of its "different sound" wasn't uninteresting, at least from my point of view...
I repeat your antics from this thread, and maybe many more in French I couldn't be bothered translating.
Cheers George
Cheers George
Of course, I would be very happy to give you more info on this nice development. But, I'm sure you'll understand that it's simply impossible to do it now, at least in this thread...🙂I mean all the test configuration you mention here.
It seems that the same causes lead to the same consequences! When someone says one thing and its opposite, it is not surprising that someone reported him ... This has been done in the thread that you mention ...
But what are you trying to prove? You do not behave like you should do: others would have simply accepted these results, that indeed you knew very well, as you said elsewhere et voila ... You just have to say that what counts is the sound and if that sounds better to your ears with distortion, why not? The story can stop here, it's up to you now...
I published scientific results on the LDR behavior in order to improve our knowledge of what is going on, you are doing personal attacks... You are not on a good trend, definitely !
ondesx,
I did not notice any personal attacks in this thread towards you. Whether it be interpreted as such due to cultural differences, I don't know. But the main issue is the same "what do we make decisions on, measurements or listening experience". From a consumer point of view, nobody is going to buy into something that seems to measure good but sounds terrible. One reason why consumers don't trust measurements is that the right data is not published. From a business point of view, there is no incentive to publish data to the extent that consumers can make decisions just by looking at data.
So, the current status is that the data does not reflect what users prefer. From my experience, it's because the wrong measured data is being referred, and you just have to figure out yourself how to get the right information based on your own listening experience.
I have suspected that the main improvement in sound is due to better impedance match over the audio spectrum, and presented some examples of what sounds better than common interface. People are welcome to explore further on their own if they so desire. Some of the minor improvements are resulting from improved continuity of signal transfer medium. The kind of distortion presented might change percieved tone a bit, but certainly not to a point that is objectable.
The simple series-shunt type volume control, whether implemented using LDRs or resistors/pots basically vary in gain and impedance for different positions (Wireless World has a good article published in the 80's on this). So when you are comparing, it's necessary to take many things into consideration, which from what I can see for now, is not done proffessionally.
I don't want to fuel the fire any more than absolutely necessary.
Imho there are issues with the sematics.
One could measure the lightspeed and based on the measurements make a statement on whether the distortion figures are good, bad, acceptable and so on.
It is however inappropriate to say that the design is bad, flawed, impossible to use in high quality applications and so forth.
It's quite clear that many people like the design very much and a lot of people rank it amongst the very best products available.
Op-amps measure good but I havn't seen a lot of op-amp desigs in the high end segment... I guess sound does matter.
Your're kidding for sure...😛ondesx,
Here there aren't "usual customers" but technicians and DIYers. Normally, these guys are interested in what is going on... Otherwise, the "normal customer", isn't interested mostly because he don't understand a freaking word of these technical data, then he goes to the store, listen to the stuff and then he'll buy what it's allowed by his wallet...But the main issue is the same "what do we make decisions on, measurements or listening experience". From a consumer point of view, nobody is going to buy into something that seems to measure good but sounds terrible. One reason why consumers don't trust measurements is that the right data is not published....to get the right information based on your own listening experience.
Impedance is obviously an important issue, but it's very well documented now. There are very simple rules to be followed which will avoid important drawbacks...I have suspected that the main improvement in sound is due to better impedance match over the audio spectrum, and presented some examples of what sounds better than common interface. People are welcome to explore further on their own if they so desire. Some of the minor improvements are resulting from improved continuity of signal transfer medium. The kind of distortion presented might change percieved tone a bit, but certainly not to a point that is objectable.
Again, I'm not sure to understand... Of course the "gain" will vary : it's an attenuator !!! And yes the impedance will also vary : the bridge is constantly changing from one attenuation value to another... All things are equal between the MkI and MkII measurements, and of course the results are perfectly comparable and moreover done by a professional electrician !... But don't take my word, please do the measurements by yourself, you can do it with a good soundboard and a FREE software !... What do you want more ?The simple series-shunt type volume control, whether implemented using LDRs or resistors/pots basically vary in gain and impedance for different positions (Wireless World has a good article published in the 80's on this). So when you are comparing, it's necessary to take many things into consideration, which from what I can see for now, is not done proffessionally.
Remember that Mr Pass already found at least part of these results and that George also knew all this, as he recalled somewhere above. If you find different results (again, it'll be a very improbable eventuality...) please, let it know to all and we'll have a new, very interesting reason to investigate !
ondexs,
Please take your behavior elsewhere. This used to be a good thread, now it seems to be all about you and your personal attacks on everyone here who answers you.
A had a good afternoon yesterday. Went to a mini-meet and brought my LDR attenuator with me. Posted pictures much earlier in the thread. We substituted it for an Aesthetix Calypso line stage. Power amps are custom 845SE amps, Gallo speakers and an Aesthetix Rhea phono stage. The Gallos use a 2nd voice coil in the woofers, driven by a SS power amp, signal from the line stage. Turntable was a custom Lenco with a huge plinth, JMW arm and Shure VMxR with the Jico SAS upgrade stylus (a very pleasant surpirse to this MC guy).
When we first tried it, there was mixed opinion in the room as to which was better, the Calypso or the LDR preamp (which is George's design with a different power supply and a set of three relay selectable inputs). The bass was deemed a bit flabby. Then we realized we hadn't connected the SS amp to the attenuator. Once connected the bass tightened up very nicely and the LDR stage was clearly better. The system owner thought it was close though.
Next step we inserted a buffer stage, a DC coupled cathode follower, servo controlled between the Rhea and the LDR preamp. I really didn't expect any improvement here, since the output tube of the Rhea is a 6922, and presumably a cathode follower which should have pretty low output impedance. Oh was I wrong. The buffer made a huge improvement: better dynamics, powerful bass, resolution of much finer detail (which in turn led to a bigger, wider, deeper sound field). Better top to bottom.
The system's owner now conceded the superiority of the LDR stage, but he asked about the power cord. I replied that I hadn't experimented with them on the buffer stage. We replaced a home made power cord (using Home Depot extension cord wiring) with an affordable Pangea AC14SE 2 meter cord feeding the buffer stage. Instantly, much finer resolution. I have no idea why this may be, but we all heard it clearly.
Bottom line, LDR preamp wins again, against a $4500+ preamp. But admittedly it lacks remote control, remote phase reversal switch, pretty looks, balanced in/out, etc.
And, don't be afraid to try a GOOD buffer. Relieving the load on your source's output stage can result in better sound, despite the addition of active and passive components in between.
Best of luck to all who try out this circuit. I think you'll be very happy.
Stuart
Stuart
onedsx
By your own admission it sounds good ( in your early posts )
By your tests maybe the figures are not the greatest.
Soooo what ?
It's not relevant - period.
It came from nowhere....meant that until you came in all of the posts were about advice, tweaks, power supply improvements, impedance matching and how everyone was using theirs generally.
Then there's an argument generated by you about small details that everyone knew already - Mr Pass, George, Soongsc and all the others who have comprehensive understanding of electronics.
I don't have this - but I don't need to - I just rely on the advice of these people and make decisions about whether to take the plunge and try something different.
Good job I did too !!
There are lots of members like me who can solder and assemble things to make music come out of the speakers - there are perhaps not so many with the intelligence and experience of George, Nelson, AndrewT, Soongsc, Uriah and even yourself who I and others rely on for good advice and positive input.
In my short time here this place has never been about squabbling - and at the moment it is.
Andrew
Soooo what ?
Andrew
well ,I'm turntable-tubes -FR boy ,distorsion is not problem for me!😀😀 I use optivol ie mkI
But I never understand why the mkII sound better, two possibility for me:
-ldr resistive element is better then shinkoh or zfoil
-add distorsion (that are there all here know)
Ps
don't replay about ladder and so on please
Ps
ondesx,
Can you discribe how one can detect distortion you measured during a listening session?
You, like many others in various cases are just trying to get people mad so that they will post things that you do not know. For people being around forums long enough, this technique does not work. It is not only a disgrace to yourself, but also to the country represented by the flag. It is already clear that you have not done enough research, and it would be much better if you did some more dilligent work to really gain respect. While I have posted much data in various forums, I can only claim that those are what I have learned, but I would seldom insist that I am correct beyond doubt. As a matter of fact, I consistently seek opinions from local audiophiles and dealers to make sure that I am not missing anything. This is a very important process in development of audio products. Trying to attack other products does not show style and dignity. You have already expressed distortion is important, and others feel different. If you cannot bring any more data to support your views, I would recommend that it's best left just like that respecting the optinion of others.
Mind that opinions on impedance issues are also very diverse. Rather than having a fight in a forum, I just went and did things the way I understood and came out with data that is compliant with my listening experience, and the listening experience of many others as well. So what I can say is, if you trust your judgement, just do it rather than waste time in arguements.
As for me, well, I have a good feeling how LDRs can benefit audio reproduction, and it will get in a design when the time and product is right.
Anyone with the passion for music that exceeds passion for being technically correct will always improve their designs.
It seems easier to admit a wrong simple concept, rather than a true one a bit harder...
Well, from now I stop any discussion with people not interested in technical data about the LDRs, since it's the major reason of the existence of this forum. I'll avoid any discussion about all subjective superiority of whatever circuit...
Then, for all guys who remain interested to understand what is going on and how to improve, if it's possible, this design, please keep posting, for any other reason don't waist your time in posting personal attacks...
joking right?
Hey!
I know there is alot of smart,KIND and knowledgeable people here so let's all get along and see if we can get back to making better audio systems,THAT'S why I Like being a member here to learn and improve,and with ALL of you guys help I have succeeded in improvements I couldn't have done or known otherwise!!!!!!!!!!!
Maybe improve the LDR..........
Thanks for listening!
- Analog Line Level
- Lightspeed Attenuator a new passive preamp
