TT
Hi Peter,
Congratulations!
Looks good,sounds good?
BTW,are the ELS self-made as well?😎
Cheers,😉
Hi Peter,
Congratulations!
Cheers,😉
Of course!😉BTW,are the ELS self-made as well?
I think so. It is certainly better than my Thorens td125. Much more relaxed and detailed. However the amp I use at the moment is having great difficulty with the ESL's and the phono pre isn't too great either so I am sure I haven't heard half of what this thing can do.sounds good
The unipivot principle seems to be working very well though. It runs very stable and quiet. Just that you have to water it every week or so 😀 😀
Very nice job! This is far more than a proto.
What is the black "stick" on top of the plinth? Looks like an on/off or arm lift or so....
Just paint it green, so you can water it while you are doing the plants 🙂
Nothing so spectacular, it is a brush to clean the needle 😀 😀What is the black "stick" on top of the plinth?
I would have doneJust paint it green
go out and build one!
DIY TT update
I have been listening to my prototype for some time now and I must say I am getting more impressed with it every time I use it.
Compared to my thorens (which used the same arm and cartridge) surface noise is way down and there is much more detail. It all sounds very easy and relaxed.
The principle of a potentially wobbly unipivot that is stabilized by a fluid works great. Only problem is the fluid (water) evaporates and therefore you must add some about once a week. But in practice this is not a problem. You can do it easily and mess free (I havent spilled a drop yet).
Perhaps I will try to float a film of oil on top of the water to reduce evaporation.
Of course there are things that can be improved upon. It was afterall just a prototype.
The first thing I will change is the bearing. Right now it consists of two pieces of POM, an 8mm steel ball out of a ball bearing and an allen bolt whose head rests on top of the ball. I intend to change this to two brass parts, a ruby ball and a POM thrustplate.
Next should be the platter. Maybe I will have the current one turned to more exact roundness or I will make a new one.
And after that who knows..
Anyway, as a result of not needing very close tolerances in the bearing this project lends itself very well to home cooking. If you have a router and a little ingenuity you can build something like this successfully for very little
VERY nice TT!
I hope I can make one just like that. Well, I think I will not steal anyones crane bucket 😀
What about some close up photos? maybe from the guts as well!!
RE:VERY nice TT!
Peter does it again. 😎
Congratulations Peter....don't forget the plants though.
Cheers,😉
Cheers,😉
thank you.PedroPO said:VERY nice TT!![]()
look at http://www.diyaudio.com/forums/showthread.php?postid=68872#post68872 and onwardsPedroPO said:What about some close up photos? maybe from the guts as well!!
Alas my camera isn't any better so closer pics don't work.
I've seen those allready!!
I want more!!!
I see you have a resolution problem on your camera...🙁
If you can manage to get your hands on a better camera, please feel free to post a few more pics, specially on the bearing.
I want more!!!
what do you want to see especially? photos will take a wile but I can post some more cad pics like these.
http://www.diyaudio.com/forums/showthread.php?postid=53065#post53065
the model is made to these plans.
I saw those allready.
My trouble is how to make the bearing. I was hoping to get a close up pic of the bearing.
I really don't know how does the plater vertical axis stays paralell with the bearing vertical axis. (is it the gyroscopic effect?)
Does the belt make a significant horizontal force that tilts the platter? If its aligned with the gravity center of the plater, then no tilting should appear.
What about the bearing body? did you have it machined?
thanks
thanks
The bearing does nothing to keep the axis alligned. This is purely done by the fluid.PedroPO said:My trouble is how to make the bearing. I was hoping to get a close up pic of the bearing.
The belt is placed in the plane of the bearing ball which is approximately in the center of gravity. In fact it is somewhat above COG. I did some quick tests but it didn't seem too critical.PedroPO said:Does the belt make a significant horizontal force that tilts the platter? If its aligned with the gravity center of the plater, then no tilting should appear.
PedroPO said:What about the bearing body? did you have it machined?
Yes, but it is nothing more than a POM rod with a hole on top and a threaded hole at the bottom. You could even make it with column drill. As long as it is solid and doesn't touch the platter it will be ok.
Intro & my table project
Hi all i have read most post with great intrest and got a great deal of inspration i had been toying with the idea of building a table for so time, after reading i decided to give it a go.
So the first thing i did was get a local engenier to make me a bearing i have ended up with a very close copy of the Teres Audio Bearing cost on this came in well under US$80 the outer portion made out of Bronze the inner out of Stainless
The platter and plinth are made out of layers of 4mm marine grade Aluminium and 19mm plastic chopping board all of these materials where scrap no cost
The spikes are maid out of modified brass plummig fittings cost less than US$12
The steel Ball Bearings dont do anything other than look cool
Any opinions good or bad are most wellcome.
NICE...
Hmmm....bearings you say?
Do you have it spinning already?
Cheers,😉
Cheers,😉
you beet platter weight 4.2kg expermenting with an old Gerrard tt motor
later
Hi Peter - dropped back in here after a while chasing my tail on the employment front...
congratulations indeed - looks good - I'm really pleased for this mega-thread that it sounds good too after some initial reports that the fluid damped platter idea looked pear shaped - can't wait for further reports after sorting your disk preamp and ESL drive troubles!
I may have missed it but did you post salient details/materials/critical bits etc in one place?
All the very best to all who have contributed ideas here - cool
Pete
Pete
Welcome back 🙂Hi Peter - dropped back in here after a while chasing my tail on the employment front...
I hope this means your business is doing so well that you can sit back and build TT's
I am working on this. For now that means collecting materials to build a nice all valve Phono-Pre-Power amp chain. Will take a while though before that reaches thecan't wait for further reports after sorting your disk preamp and ESL drive troubles!
http://www.diyaudio.com/forums/showthread.php?postid=130186#post130186 is the closest I got. But if you have any specific questions just let me know.I may have missed it but did you post salient details/materials/critical bits etc in one place?
Hear hearAll the very best to all who have contributed ideas here - cool
Out of curiosity, has anything become of the airbearing plans that we saw in the beginning of this giant thread?
- Analogue Source
- Let's make a DIYAUDIO TT
