Let me lite fire - Nelson Pass F1
Grey
Well understood. Helpful and amusing.
Please remember, two or at least one Rgs is adjustable.
This is to let the DCs at the output nodes face the same value.
And . . .
I will rewrite . . . when the outside weather is cooled down . . . when my head is free from smell of alcohol . . . and when I finish cleaning up my desk for two week holidays . . .
jH
I think that F1 is a single stage circuit.
I believe that I could adjust the DC offset rather easily even if I use unmatched gain mosfets. I am considering one of two ways.
(1)
Having one adjustable resistor in the load current source system.
(2)
Or, having one adjustable Rgs.
As Nelson has said many times, I should first adjust dc offset at cold operation condition, then, adjust once again at warm condition.
I think that method (1) would assure me the stable dc offset.
Am I too optimistic . . . ?
Could you please give me wake-up call . . . ?
jH
E.g. like this.
jH
Heat sinks arrived . . .
Trafo will come soon . . .
O! I changed mind . . . It will be one 20-0 20-0 800VA, sized 152mm dia and 93mm high . . .
The one remaining thing I am concerned about is whether the gate voltage of the current sink (lower ccs), about 4V, will be stay fixed or not. Here, as Nelson tipped, the stability of the drain Q voltages is a matter. Still I am not 100% sure of . . .
jH
Thanks for all of your encouragement.
Steenoe
I will see . . . and if necessary . . . will put the legs on the face plate . . . 🙂
If so . . . the name Pass F1 will become a** holes . . . 😱
Here shows how I do hole-marking.
jH
Nelson
I can't understand what are the causes of the unstable dc at drains.
The Vbe varing with temperature in deck ccs could be one reason.
The gate voltage of the bottom ccs must be stable so that it could not be a concern. But, the drain voltage of it could vary, as you say, so that it could be another reason, and probably this would be the most concern.
If so, could I sense the varying darin voltage and cure it in simple way? Could you give me a tip?
Don't say, "you will see it in a month or sooner . . . Muuuuuuhahahahahahaha . . ."
jH
Trafo arrived . . .
That hardware is sweet looking! You've just got to love the sight of a rod of IRF's😀
Almost, "Like a virgin".
I am not sure Mr. Pass is up to revealing the details yet. As I understand from the postings on that matter, you have to wait till the end of this July:smash:
Well, you signed the papers, but didn't get rid of me🙄
Thats the way it works😀 😀
Steen😎
Steen
You did wrong. Really wrong. Nelson was about to inform some.
But, you made him shut up. You know? I do not trust him much.
His one month could be three months for us. No alimony for you!!! :headshot:
Grey
Your hint makes me further confused. Hmmm . . .
Ok, I will post my circuit tomorrow . . . because I know mine is
different from the Firstwatt F1. So, it should be no problem.
Isn't it right, Nelson . . . ? I would like to hear all your opinions on
it.
jH
You are giving away! . . . nevertheless, not enough yet!!
I am tired of this hot weather . . .
And now tired of holiday beer . . .
Here is my preliminary circuit.
P1 is to adjust the offset close to 0 at output.
Nelson says in the Zen V7 article: ". . . by a single ended input . . . one input is driven and the other is grounded and we see some voltage swing occur . . . and thus also on Drain of Q3 . . . variations as much as +/-3 Volts . . ."
I think that he developed F1 mainly for tube preamp users, i.e. for the single ended pre. Then, to him, the voltage of variations of +/-3V must have been 😱
For the same reason, I would like to have R23 and R24. This is to make an ac ground at the drain of Q5. If it works as I think, the dc voltage across the bottom ccs could be getting stable.
I wish to hear from you about all kind of comments.
Any give-away-! comment would be appreciated.
Phew . . . I am sweating too much . . .
I need more beer . . .
I will try this circuit until I get the efficient single unit drive . . .
jH
