Lack of Bass - Dallas II Horn
Well, for a start it should cost less and be easier to run & keep out of the way (if those are issues). And if you happen to accept Hawksford's view on electromagnetics, the thin wire is one way of adhering to his interpretation. I don't myself, but many do, so for them it ticks that box too. And so on & so forth. However, this is potentially off topic as this thread is about trying to help the OP, not discussing theory.
The angles of front & rear referred to should not have a catastrophic affect on LF response. However, the 206 was designed to be used with higher amplifier output impedances, and this was partly factored into Dallas II. What you do have to be careful of, as Dave alludes to, is the avoidance of leak paths in the horn. Any gap or bleed through between panels can and does rapidly compromise the load and the LF output quickly drops off as a result. In most practical cases, Dallas II should be good for roughly mid-40Hz regions in-room with reasonable gain, so if you're not getting that, something is awry somewhere.
The OP could use resistors to determine the best value to get him the bass he wants, then he could use thin fragile wire of similar resistance. It's usually best to use as short a speaker wire as possible which could make using resistors a better option.
Hey Vlad,
Maybe you could borrow a more suitable amp to see if it helps with your problem. That and if you have internal stuffing try playing around removing some, o Dr stuffing can kill base response, don't know in the Dallas calls for stuffing though.
Paul
So why did you say "no"? I was saying that it's not necessarily the worst case, and giving an example of how and when it isn't.
Looks to me like between you, you've run afoul of the rather blunt tool that is the written word.
You both agree that a resistor can get the job done, although thin wire means you don't need to add an extra connection.
Any chance the design could do with some BSC, and/or some kind of filter to tame the often rising response trend of the Fostex FE range?
My other question would be what's being used as a reference. If it's some bass-heavy headphones, I can imagine that a ~flat speaker would leave them wanting more.
Chris
I am used to a Geneva sound system L, which is poor in sound and especially bass compared to a stereo system.
I have used 1/8 inch of wool felt in the driver cabinet.
There is predominate bass in the interior of the horn; I do not know if this detail is of use.
Thank you again,
