Krell KSA 50 PCB
Crown used something like that on the early DC-300's. I think they called it a "bootstrap capacitor". Anyway, that old design is not the way to a good KSA-100! The MK-2 I believe took care of many of the ailments of the early versions of the amp.
To me the next step for this site although in a seperate thread would be the KSA-100MK-2 since we have the drawings and since its not all that much more complicated than the 50 is. The MK-2 amp can also be built as the KMA-100 which had the addition of a regulated supply for the main board and was a monoblock.
Mark
Krell progressing...
I have now modifyed, my chassis, the 2 duct fans will be controlled separate by NTC resistors, and the fans at the heatsinks will be controlled together by 1 NTC.
Idle speed will be about 4 v and max speed at 10,5 v
Still a long way to go.
Hi Rovsing,
The hot end of your sinks should have the output devices farther apart compared to the cooler end. Which way are the fans blowing/sucking? Moving the hot end ones towards the centre nearly achieves the same thing.
BTW, I would put the fans on the outside so we can see them clapping😉
The sinks you are using have fin spacing to suit natural drafting, so they won't dissipate quite as much heat as close finned sinks designed for fan cooling but they look plenty big enough. What is the Pd you are planning on using?
Hei Andrew
The fans are blowing through the duct, if you look at the new picture that i have attached, you can see that the heatsink got a Y shape, that's why i have put those plates at the top(haven't fastened them yet) to make a triangular duct for the upper fans.
If this construction can't keep the heat away, i will trow this thing out !😀 It has already got much bigger than first planned.
D=400 mm H=175 mm W=475 mm
hi Konst
If you got a good eye fore it i'm sure you could make a good income collecting garbage !
Amazing what people trows out nowadays.
Here's a picture of the NTC's mounted in the opposite end of the fans.
ROVSING said:
hi Konst
Once it's running you can get rid of the heater under the table😀
put on some red and yellow leds, a bit of clear loose plastic flapping
in the fan exits, wood on top.
tell the wife it's and artificial wood fire heater:clown:
thought i would beat Upupa:clown:
seriously,
nice work😀
allan
ps i really do feel imspired to finish of mine.
Very slick metalwork ROVSING. You obviously have better metalworking-skills than me.
btw, heatsinks im using are also salvage parts from electromotor-softstarter at my work. when i saw them i knew they were mine 😉
Keep up the good work !
with kind regards,
Klaas
