Krell KSA 50 PCB
My bridges get fairly warm as Stuart mentioned they would be. Mine are mounted in the origianl Krell fashion..... right onthe caps..... just makes things alot easier to wire with shorter wires too. Note the white grease peeking out from under the bridge.
jacco vermeulen said:
is it me, or are those metal strips really Fat ?
Anyone ever experimented with putting a metal layer on copper ?
I have these gorgeous copper strips i'd like to use for the Krell PS, and would like to sheet them.
Calling Mr Electrolysis,long distance.
Silver plated some Copper Bus bars, not sure If I would do it again.
Anthony
Ok, it seems the concensus is for no major changes, so I will just redo the drill file, and mail it over to Mark.
Thats great! I will be in Idaho this week again but will have the laptop with me.
Jacco,
Those are alumnium bars approximately 4.750" long X 1.675" wideX .375" thick(you convert to metric). They provide some heat sinking for the bridges and keeps the buss wiring very short.... yes that are about twice as thick as the original Krell bars were. Nuttin wrong with that though. BTW, there is anti-oxidization compound under the screws and star washers. Yeeee-haaaaa!(we still say that out in the west sometimes)
Mark
two suggestions for the Wiki build pages.
1. How to calculate the resistors that control the quiescent current in each of the stages. Particularly for those who have a different transformer voltage.
2. What range of quiescent current suits each stage and what effect does each have on operating parameters and sound quality.
Mark,
Where does one get hold of those bus bars?
Alu don't plate easily----far from.....
If you use copper bars, it would need a layer of rhodium first, to enhance adhetion.
Why not use the alu as is? It is fairly non-corrosive by nature, polishes easily - and so does copper..........................
HMMM----Don't say the gold would enhance the sound......????
