I still have a pair of these: http://www.diyaudio.com/forums/swap-meet/201773-fs-ksa100-clone-pcbs.html
please take a look at Newark
1N5309 - AMERICAN POWER DEVICES - CURRENT REGULATOR DIODE, 600mW | Newark/element14 Mexico
Let me know if I can help.
Best regards
Ramon Amandi
Thank you Ramon. I will try them.
Thanks VT67 for your offer, however it seems like I came right with a set from Loek, which should be on it's way to me right now.
KSA50/100
I should have mentioned that Jim's Audio KSA50 was available as KSA100 by adding a few different components and more output boards. Search diyaudio for KSA100 Jim's Audio. But you have yours now. Good luck, spurltespurlte
I have the KSA50 already, mine is entering the last stages of completion and hopefully by the end of the summer holiday (here in southern hemi) it should be singing. I was refering to the KSA100.
Thanks to Loek for graciously offering up his PCBs for me, and they should hopefully be here soon.
Soon I might however have to grovel in front of Jacco for some 1N5309 CRDs, if he still has some left. Mouser has them, but only for a minimum order or 2500 units. Yikes!
KSA100boards
Not yet Henry. I found the CRD's(5) and have also the SMD fets and a bunch of Dale resistors. So if you are interested in the components we have to agree a price for them and i can include them in the package.
Sorry Walter......
Regards, Loek
Sorry Walter......
Regards, Loek
Where can I buy Toshiba 2SC2238 and 2SA968 original transistor. Thanks to anyone who can help me.
It's a typical Driver type transistor.
160Vce0, 1.5A, 25W, 100MHz fT, 30pF Cob, 100hFE
Choose anything that matches.
Krell KSA 100 MKII station building, I hope to finish it in a few months.
It remained the only pair of transistors 2SC2238 and 2SA968 not find them. Transistor: MJE15032, MJE15033, MJ15003, MJ15004 ordered from Mouser, 2SC2240, 2SA970 ordered from hifituning24.de, 2SK2013, 2SJ313 ordered from Ebay user alweit of Israel.
Toshiba 2SC2238 and 2SA968 looking on Ebay are from China and Hong Kong do not expire no confidence and I think other users diy audio. I want to use the same transistors.
2SA968, 2SC2238
have you had luck in locating your transistors? How far are you with the KSA-100? Where are you going to get your output heatsink?Krell KSA 100 MKII station building, I hope to finish it in a few months.
All I need to finish my KSA-100 are a set of fan type heat sinks. Even FIX is out of them. I found these on ebay but wonder if they are big enough.
1pcs Aluminum Heatsink for Amplifier ?Fan Type 300mmx93mmx63mm | eBay. Suggests anyone?
[/QUOTE]
1pcs Aluminum Heatsink for Amplifier ?Fan Type 300mmx93mmx63mm | eBay. Suggests anyone?[/QUOTE]
Looking at this heatsink...
It`s center stem is too thin for proper heat conduction of a pure class A as a Krell KSA100.
It`s a poor copy of the original heatsink.
Single transistor which I found Toshiba 2SC2238 and 2SA968. On Ebay I do not inspire confidence in buying from China and Hong Kong.
I miss filtering capacitors are not decided on its purchase and I are missing a few pieces. Krell finish in 4 months.
Build two monoblocks in class AB and if you are satisfied with the sound, like in about 1 year 2 monoblocks class A building with passive cooling.
Toshiba 2SC2238, 2SA968 transistors original find, U.S. ?
I've built 9 channels for LCR tri-amped speakers using this thread. After 6 month of running fine, one of the channels started to die every half an hour or so. The reason is failing Q3 (negative rail LTP "input" transistor, the left bottom 2SA970 on the schematics). Here is what I see after failure:
1) Dead transistor measures with ohmmeter fine.
2) Amplifier output is close to the negative rail (-45V).
3) Q3/Q1 base are about - 5V
4) After replacing the transistor everything seems fine.
Here is what I've done except just replacing transistors about 7 times already:
1) Put DC blocking capacitor on the input
2) Put 2 by 3 diodes between Q1/Q3 and Q2/Q4 bases in opposite direction to protest the Q1, Q2, Q3, Q4 EB junctions from reverse voltage
I have separate power supplies for LTPs and VAS + output. The first one is stabilized 60V shared with the other 3 channels on the same chassis. The second one for this particular channel is 45V. The input is from a crossover on the same chassis.
What can cause it?
What can cause it?
I’m thinking to double output transistor amount.
I have drivers MJE15032/33 and I’m planning to use 8 pairs MJ15024/25 for output.
So one MJE15032/33 will drive 8 pcs MJ15024/25.
Is there something I should be known or take special care?
Feel free to take it to the extreme if you like walking on the edge.
twice the load on the driver stage plus cutting it`s ability by 50%.
it`s a sure recipe for overload and circuit failure. but hey, it`s your money...
Why? What if he will keep the total bias the same? Even if the total bias current will be twice of original will it put the drivers outside of SOA?Feel free to take it to the extreme if you like walking on the edge.
- Krell KSA 100mkII Clone
